Hi
We are wondering if its a problem that you have been made aware of and if so we are wondering if a fix for the problem is expected anytime soon for admin purposes of our users machines, added a description too the problem we met and how we solved it incase anyone is experiencing the same and too privode more insight.
Intel Unite have failed with error code and error log
Error code Event ID:
Event ID: 1000 Application error
Eventdata:
Log:
[14.12.2018 13.54.33] EXCEPTION: Getting lync client - The host process is not running
ved Microsoft.Lync.Model.LyncClient.EnsureOI()
ved Microsoft.Lync.Model.LyncClient.GetClient(Boolean sideBySideLync)
ved Intel.CFC.CFCUI.MainWindow..ctor()
[14.12.2018 13.54.33] ModeratedMode: Unmanaged
[14.12.2018 13.54.33] vPro Check. Is vPro Platform=True
[14.12.2018 13.54.33] Started creation of WebRTCDesktopStreamer in SlowInit thread
[14.12.2018 13.54.33] Slow Init - Host name set
[14.12.2018 13.54.33] Starting Plugin Load
[14.12.2018 13.54.33] Obtaining the plugin list
[14.12.2018 13.54.33] EXCEPTION: Get Plugin List - Finner ikke en del av banen C:\Program Files (x86)\Intel\Intel Unite\Client\Plugins.
ved System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
ved System.IO.FileSystemEnumerableIterator`1.CommonInit()
ved System.IO.FileSystemEnumerableIterator`1..ctor(String path, String originalUserPath, String searchPattern, SearchOption searchOption, SearchResultHandler`1 resultHandler, Boolean checkHost)
ved System.IO.Directory.GetFiles(String path, String searchPattern)
ved Intel.CFC.Plugin.CFCPluginManager.<LoadPlugins>b__13_0()
Problems occured after a new GPU driver update for Intel(R) HD Graphics 620 with windows update.
Solution:
Roll back drivers for the Intel(R) HD Graphics 620 too previous version. testet and working.
Hope this helps if anyone else is experiencing the same problems.
Best Regards.
