Intel Unite® App
Gain crucial understandings of the Intel Unite® App
This product has been discontinued. This board is currently read only and no longer accepting new posts. Learn more
459 Discussions
Intel Unite compatibility NUC and stand alone installation
EMore11
NUC Model : NUC7ieBNK
Hello I have an Intel NUC7i5BNK and I would like to use the Intel Unite application to share the contents of client computers on our screen.
Is this model compatible?
Is it possible to do a Stand-Alone installation instead of a server installation?
ATec
Not sure if the NUC7i5BNK is supported for Intel Unite, I don't see it in the list of validated Mini PCs for Unite, which can be found at the bottom of this link under "Shop Top Intel® vPro™ Platform-Based Computers Enabled for Intel Unite® Solution". We will need a Intel's rep to confirm if this model is compatible.
https://www.intel.com/content/www/us/en/architecture-and-technology/unite/intel-unite-overview.html
Stand-Alone installation was designed for use by Small Business Deployment. "Formerly known as Standalone mode, the new software version (v3.1) has been named Intel Unite®for Small Business".
Small Business is only supported for Intel Unite version 3.x. If a Intel NUC is compatible with Unite you can run either unite 3.x or 4.x, but for Small Business you will need to go with version 3.x.
Small Business User Guide for the Intel Unite® app
https://www.intel.com/content/www/us/en/support/articles/000008493/software/software-applications.html
Intel Unite v4 is a different architecture and it must run in a enterprise environment with a Server and should not be considered an upgrade from v3.
DrËw📡✌️
Leonardo_C_Intel
Hello Everybody The information shared by ATec is correct the Intel® NUC7i5BNK in no validated as a HUB you can use Intel® NUC7i5DNKE (information available: https://www.intel.com/content/www/us/en/architecture-and-technology/unite/intel-unite-overview.html). If you need to use the Intel Unite® standalone set up you have to use the version 3.x as advice by ATec. Regards, Leonardo C. Intel Customer Support Technician Under Contract to Intel Corporation
Leonardo_C_Intel
Hello Everybody Was this information useful for your inquiry? Regards, Leonardo C. Intel Customer Support Technician Under Contract to Intel Corporation
Leonardo_C_Intel
Hello Everybody I haven’t heard back from you; please contact us if you have any additional questions. Regards, Leonardo C. Intel Customer Support Technician Under Contract to Intel Corporation
