Intel Unite® App
Support for the Intel Unite® App
The Intel sign-in experience is changing in February to support enhanced security controls. If you sign in, click here for more information.
457 Discussions
Intel Unite not running on Intel NUC7i5DNKE with vPro
MHamo
I'm having trouble getting Intel Unite 3.2.82.42 to run on a new Intel Gen 7 NUC with vPro (NUC7i5DNKE), with latest Win 10 Enterprise
Installation of hub completes and I can configure the settings, but when I run the Hub I get the error
Intel Unite app cannot run on this hardware configuration,
Please check with your platform vendor for more information.
error ID666666.
Any suggestions?
Hello _Mark_
Thank you for contacting us regarding the error that the Intel® Unite 3.2.82.42 is displaying when try to run the HUB.
In order to help you better I would like to gather more information about the configuration you have in the computer. Please attach to this thread the .txt file the Intel System Support Utility will generate https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
To attach a file, you must click •Use Advanced Editor" on the upper right hand corner of the response box, then the "attach" option will appear on the bottom right hand corner of the response box.
I hope to hear from you soon.
Diego S
MHamo
Hi Diego,
Here's the Intel System Support Utility output.
Mark
Hello _Mark_,
Thank you for our response. I really appreciate it.
In this case, can you please go ahead and uninstall our Intel Unite® app?
After that please go ahead and perform a BIOS Update by following any of these steps:
https://www.intel.com/content/www/us/en/support/articles/000005636/mini-pcs.html https://www.intel.com/content/www/us/en/support/articles/000005636/mini-pcs.html
It seems that the issue that you are experiencing might be related to the BIOS of your machine. Your current BIOS has the version 0026 while on the other hand the latest version is 0039.
However jumping from the version 0026 to 0039 is not fully recommendable, so please go ahead and jump from 0026 to 0031 and then from 0031 to 0039.
Here you will find the 0031 version:
https://downloadcenter.intel.com/download/27353/BIOS-Update-DNKBLi5v-86A- https://downloadcenter.intel.com/download/27353/BIOS-Update-DNKBLi5v-86A-
After this one is installed please install the latest BIOS here:
Once that your machine is up to date please reinstall again the Intel Unite® App and test it out.
Please perform the steps and monitor the results so you can let us know the outcome.
I hope this helps,
Diego S.
MHamo
Thanks Diego,
The firmware updates fixed it.
Mark
