Intel Unite® App
Support for Intel Unite® App
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
For the latest information on Intel’s response to the Log4j/Log4Shell vulnerability, please see Intel-SA-00646
452 Discussions
Intel Unite with Dell E7250 get error ID666666
QVuon
Hi Intel,
I installed Intel Unit Hub.mui.msi on my laptop Dell E7250 with vPro. Then get the error as below:
I
Community Manager
Hello, WuyenVU.
Thank you very much for sharing your issue with the Intel® Communities Team.
I understand you are having an issue running Intel Unite® on your DELL™ laptop which is giving you an ID666666 error. Allow me to help you regarding this problem you are facing.
This error indicates that this device is a non-certified Intel Unite® Hub Device.
I will highly recommend you to get in touch with http://www.dell.com/support/home/us/en/4 DELL™ Support to verify if this unit will support Intel Unite® or how this issue can be solved.
Antony S.
