Intel Unite® App
Gain crucial understandings of the Intel Unite® App
This product has been discontinued. This board is currently read only and no longer accepting new posts. Learn more
459 Discussions
Intel Unite with Dell E7250 get error ID666666
QVuon
Hi Intel,
I installed Intel Unit Hub.mui.msi on my laptop Dell E7250 with vPro. Then get the error as below:
I
Hello, WuyenVU.
Thank you very much for sharing your issue with the Intel® Communities Team.
I understand you are having an issue running Intel Unite® on your DELL™ laptop which is giving you an ID666666 error. Allow me to help you regarding this problem you are facing.
This error indicates that this device is a non-certified Intel Unite® Hub Device.
I will highly recommend you to get in touch with http://www.dell.com/support/home/us/en/4 DELL™ Support to verify if this unit will support Intel Unite® or how this issue can be solved.
Antony S.
