Intel Unite® App
Gain crucial understandings of the Intel Unite® App
This product has been discontinued. This board is currently read only and no longer accepting new posts. Learn more
459 Discussions
Intel unite 4.0 server install admin page getting 503 error
YPate11
I have Installed unite server with mssql database but when i go to admin url getting error 503
and inteluniteadminportalpool keep stopping every time i try to access admin url.
please help need this working asap.
thank you
attaching log
Wanner_G_Intel
Hello YPate11,
Thank you for posting on this Intel Community.
Please check the following information to troubleshoot this issue:
1. Requirements: .NET 4.6.1 or greater
2. What type of authentication are you running on the database? (e.g. Mixed mode authentication or Windows Authentication mode)
3. Are you following the steps to create the database for Intel Unite® found on the Intel Unite® Deployment Guide?
Wanner G.
Under Contract to Intel Corporation
YPate11
  1. updated to 4.6.1
  2. running mixed mode
  3. following guide
  4.
still getting the 503 error and inteluniteadminportalpool service keep crashing every time i try to access portal URL
Wanner_G_Intel
Hello YPate11,
Based on the information you have provided, this issue is most likely an IIS configuration issue:
Please check that you have installed the URL Rewrite and the SHA2 certificate. Also, make sure Windows* Server is up to date.
Wanner G.
YPate11
So after server update admin portal working now
I went on to hub and clicked on provision device url
now getting error
Unable to get configuration settings. An internal error has ocurred.
on server i found this error
Event code: 3005
Event message: An unhandled exception has occurred.
Event time: 7/17/2019 4:12:24 PM
Event time (UTC): 7/17/2019 8:12:24 PM
Event ID: b33828e8f1dc4961af14750839c1acad
Event sequence: 2
Event occurrence: 1
Event detail code: 0
Application information:
  Application domain: /LM/W3SVC/1/ROOT-1-132078679443072321
  Trust level: Full
  Application Virtual Path: /
  Application Path: C:\inetpub\wwwroot\
  Machine name:server
Process information:
  Process ID: 3772
  Process name: w3wp.exe
  Account name: IIS APPPOOL\DefaultAppPool
Exception information:
  Exception type: HttpException
  Exception message: A potentially dangerous Request.Path value was detected from the client (&).
  at System.Web.HttpRequest.ValidateInputIfRequiredByConfig()
  at System.Web.HttpApplication.PipelineStepManager.ValidateHelper(HttpContext context)
Request information:
  Request URL: https://hub.domain.com:443/IntelUnite/api&orgId=4353B2A-212E-4C34-BF11-5465454BE230D30&orgName=SID
  Request path: /IntelUnite/api&orgId=4353B2A-212E-4C34-BF11-5465454BE230D30&orgName=SID
  User host address: 192.48.75.184
  User:
  Is authenticated: False
  Authentication Type:
  Thread account name: IIS APPPOOL\DefaultAppPool
Thread information:
  Thread ID: 7
  Is impersonating: False
  Stack trace:  at System.Web.HttpRequest.ValidateInputIfRequiredByConfig()
Custom event details:
please suggest thank you.
Wanner_G_Intel
Hello YPate11,
Thank you for the update.
You may receive this error message if:
  • The Hub and Client package files have not uploaded to the Admin Portal
  • Hub/Client configuration has not been created nor assigned.
Please review the section 4.6 Configure the Enterprise Server for Intel Unite® Solution for configuration details.
Wanner G.
YPate11
Hub and client package files have been uploaded to portal
hub/client config has been created and assigned
still getting this error
Wanner_G_Intel
Hello YPate11,
We will send you a new Intel Unite® app version to the email address associated with your profile.
Please install it and let us know if the issue persists.
Wanner G.
YPate11
do i need to update server also or just hub and client.
thanks.
Wanner_G_Intel
Hello YPate11,
Please update the Client and Hub only.
Wanner G.
YPate11
I have update hub and client to 3754 and updated all pacakges in admin portal to 3754 but still getting same error.
Wanner_G_Intel
Hello YPate11,
Please provide us with the log files and information requested via email to gather more information about your configuration.
Also, please attach a screenshot of the error you are receiving.
Wanner G.
YPate11
I was able to make it work after i deleted the AD config from IIS.
Hub is working
hub welcome screen show 3 step how can i modify this to show url to download client to users.
thank you for your help
Wanner_G_Intel
Hello YPate11,
Please check the Hub Group Properties on the Deployment Guide to modify the default values available.
7.3.1.1.3.3 Hub Group Properties (Page 69-70)
Wanner G.
Wanner_G_Intel
Hello YPate11,
Were you able to review the Hub Group Properties?
If you need further assistance, please let us know.
Wanner G.
Wanner_G_Intel
Hello YPate11,
We have not heard back from you, so we will close this inquiry. If you need further assistance, please post a new question.
Wanner G.
A Contingent Worker at Intel
