Please tell me if Windows 10 IOT is supported for Intel Unite Hub.
tokazaki: Thank you very much for joining the Intel® Unite app communities. We will do our best in order to try to assist you with the information you are looking for.
In regard to your question, are you referring to the Intel® Unite Small Business or Enterprise?
The reason for this question is that I will do further research on this matter to provide the most accurate response, so I wanted to confirm that.
In the meant time I found the forums site from Microsoft, in there you might be able to get useful information about this matter:
https://blogs.windows.com/buildingapps/2016/04/05/windows-10-iot-build-2016/ https://blogs.windows.com/buildingapps/2016/04/05/windows-10-iot-build-2016/
Any further questions, please let me know.
Alberto R
Hi Alberto R, I am referring to the Intel® Unite Small Business only. Not to Enterprise. Thanks
tokazaki: You are welcome. Thank you very much for clarifying that information. On the link below you will find a list of products that were validated to work as a hub with the Intel® Unite application, if the product you are using is not showing there, then when you try to install the it you will get an error message stating the platform is not validated:
https://www.intel.com/content/www/us/en/architecture-and-technology/unite/intel-unite-overview.html https://www.intel.com/content/www/us/en/architecture-and-technology/unite/intel-unite-overview.html
Additionally, just to let you know, those are the products validated for hub, for client you can use any version of Windows® 7, 8, 8.1 and 10.
Alberto R
Hi Alberto R, Thank you for your kind clarification and advice. I understand that Windows 10 IoT is supported for the products validated for hub in the list, but it depends on each OEM OS support policy. Am I right? Thanks.
tokazaki: You are welcome. Yes, you are correct, it will depend on OEM OS support policy.
Alberto R
Thank you for your confirmation.
tokazaki: You are very welcome.
Any other inquiry, do not hesitate in contact us again.
Alberto R
