Intel Unite® App
Gain crucial understandings of the Intel Unite® App
This product has been discontinued. This board is currently read only and no longer accepting new posts. Learn more
459 Discussions
MacBook Connection
mainisaa
I have Intel Unite and connected to my MacBook.
Seems like the display to the extended screed is working fine but there is a box at the top-right-hand side of my screen and it is really annoying.
How to remove the box?
Not only happened at my laptop but also others colleague.
Thanks!
Wanner_G_Intel
Hello mainisaa,
Thank you for posting on this Intel Community.
To better assist you, please provide us with the following information:
1. A screenshot showing the "box" you are referring to.
2. Intel Unite® app version running in your environment.
Wanner G.
Abigail_G_Intel
Hello mainisaa,
If you still need further assistance, please provide the information requested in our previous post.
Abigail G
Under Contract to Intel Corporation.
Wanner_G_Intel
Hello mainisaa,
We have not heard back from you, so we will close this inquiry. If you need further assistance, please post a new question.
Wanner G.
jsmit211
  1. Quit Box Sync. For this, click on the Box Sync (small b) icon in the menu bar and select Quit.
  2. Open the System Preferences → Extensions → Finder → find Box Sync Finder Extension in the list of the items and untick it.
  3. Open the Applications folder → select Box Sync.app → remove the executable file by dragging and dropping the Box Sync icon to the Trash.
  4. Delete the Box Sync folder on your Hard Drive if you do not need your files synchronized in the folder. By default, it is located in your user’s folder, Users/username/Box Sync. But you may have moved it to another place for your convenience. In this case, use the Finder’s search bar and type Box Sync to find and delete this folder.
  5. The next step is likely unfamiliar for the average user, but it is required. You have probably heard that every application creates additional temporary service files on your disk. Even after you have deleted the Box Sync application’s executable file, its service files are still stored on your Mac. They are useless and take up storage space, so you should get rid of them as well. Generally, the service files are stored in your user’s Library Folder, which is hidden by default. To get access to this folder, open Finder → click Go in the menu bar → Go to Folder → in the window that appears, type ~/Library and click Go. Within the user’s Library folder, find and remove all files and folders related to Box Sync in the following subfolders:
  6. Complete the Box Sync removal by emptying the Trash bin.
If you are still facing this error then Macbook Repair Singapore is the right place where you can ask for help.
