Is there any possibility to have Intel Unite Hub and mirracast working at same time on same PC (pc with hub software)?
I don't say screen sharing at this same moment, but to have possibility to use Unite or Mirracast for example from mobile.
Because when i turning on availability to share on PC screen (in win10 remote display options) then I can't connect using Unite.
Is there a way to have this two options of remote screen sharing?
Hello tadamo,
I understand that you would like to use both Miracast* and Intel ® Unite in the hub system.
Regarding this, I would like to gather some more information about your current configuration. First, please provide me with the model of the unit used as a "Hub". Second, are you using Intel ® Unite Small business or enterprise?
Also, please let me know the version of Intel ® Unite you are currently using.
David V
For the hub I'm using Dell optiflex 7050 and it is connected to the network through ethernet cable so it don't use wifi network card/connection.
I'm using Intel Unite small business, ver. 3.2.82.42
Hello tadamo,
Thank you for your response.
I am currently reviewing the information you have provided and will be getting back to you as soon as possible.
Thank you for your time.
David V
Hello tadamo,
Thank you for your patience.
After some research, I was actually able to find out that, in fact, you are able to use Mirracast* and Intel ® Unite in the same unit. Nevertheless, you will not be able to use it at the same time.
I apologize for any inconvenience.
David V
Hello tadamo,
I am following up with your case and see that we have not heard back from you.
If you need more assistance do not hesitate to reply.
David V
Topic Options
