Intel Unite® App
Support for the Intel Unite® App
456 Discussions
Mirracast and Intel Unite at this same time
TAdam5
Is there any possibility to have Intel Unite Hub and mirracast working at same time on same PC (pc with hub software)?
I don't say screen sharing at this same moment, but to have possibility to use Unite or Mirracast for example from mobile.
Because when i turning on availability to share on PC screen (in win10 remote display options) then I can't connect using Unite.
Is there a way to have this two options of remote screen sharing?
Community Manager
Hello tadamo,
I understand that you would like to use both Miracast* and Intel ® Unite in the hub system.
Regarding this, I would like to gather some more information about your current configuration. First, please provide me with the model of the unit used as a "Hub". Second, are you using Intel ® Unite Small business or enterprise?
Also, please let me know the version of Intel ® Unite you are currently using.
David V
TAdam5
For the hub I'm using Dell optiflex 7050 and it is connected to the network through ethernet cable so it don't use wifi network card/connection.
I'm using Intel Unite small business, ver. 3.2.82.42
Community Manager
Hello tadamo,
Thank you for your response.
I am currently reviewing the information you have provided and will be getting back to you as soon as possible.
Thank you for your time.
David V
Community Manager
Hello tadamo,
Thank you for your patience.
After some research, I was actually able to find out that, in fact, you are able to use Mirracast* and Intel ® Unite in the same unit. Nevertheless, you will not be able to use it at the same time.
I apologize for any inconvenience.
David V
Community Manager
Hello tadamo,
I am following up with your case and see that we have not heard back from you.
If you need more assistance do not hesitate to reply.
David V
TAdam5
I understand everything. Thanks for the information.
