According to the setup document there is a requirement to have a "WebEx account which has permissions to view all scheduled meetings for your site" (section 2.1 of the setup document)
I reached out to our WebEx provider to get clearification on how such permissions are given to a WebEx account. Here is the message I sent to them:
"I am looking to setup the Intel Unite Plugin for WebEx. Looking through the setup document there is a requirement to create a WebEx account that has permissions to view all schedules at our site. Could you provide instructions on how to configure a WebEx account so that it has view permissions to all scheduled meetings for a particular site? Is there a document that explains how to complete this process?"
Here is the response I got:
"I asked for our advanced support team to take a look into the issue. The wording Intel is using is not the same as the terminology we use. I would suggest reaching out to Intel directly to see if they have the names of the settings that need to change."
Can someone (preferably from Intel) better explain how such account would be created?
While I appreciate the response I feel you didn't fully understand my question. My post implied that I already read the setup document. My issue is that I asked our WebEx provider to create the required account and they stated "I asked for our advanced support team to take a look into the issue. The wording Intel is using is not the same as the terminology we use. I would suggest reaching out to Intel directly to see if they have the names of the settings that need to change."
I fully understand the setup document but could you explain how to create a "WebEx account which has permissions to view all scheduled meetings for your site" as our WebEx provider says that wording doesnt make sense.
Thanks! I look forward to the update. I have also reached out to our WebEx provider (westuc.com) as well as Cisco directly trying to get info on how exactly someone creates a "WebEx account which has permissions to view all scheduled meetings for your site". Both of them replied and said Intel needs to clarify what they are asking for.
@Wanner_G_Intel We keep getting "connection failed" when we test the connection from the webex plugin installer with the corporate webex account details that we provided. Weuse SSO to login to our corporate webex accounts. Could that be the reason why it's failing to connect and if yes, How do we work around this? We really need this webex plugin to work.
Thank you
