Intel Unite® App
Gain crucial understandings of the Intel Unite® App
457 Discussions
One Time Use Intel failed to connect
DT6
Now we are testing Intel Unite solution.
One time Use client not connecting to the Server.
There is possibility to add command into client install ? - msiexec /i "Intel Unite Client.mui.msi" PINSERVER="server.name.net" INSTALLTYPE="Enterprise" ?
Hello:
Thank you very much for joining the Intel® Unite™ app communities.
In order to better assist you, please provide the following information:
Please provide the sku or ordering code of the computer?
Please provide the brand and model of your system?
Which the Intel® Unite version you are running as a hub?
What is the current BIOS version of the computer?
Which Windows version are you using?
Please try a BIOS update to the latest version on your system, and then try to run the software again.
Please let us know the results of trying the step above.
Any further questions, please let me know.
Alberto
DT6
hub machine - Lenovo M900 tiny with fi-wi card.
Cleint machine - Lenovo T440
Version Intel Unite - latest
BIOs version - latest (not really understand how it's related to issue ?)
Windows 7
I am just want to add command line into download package.
Hello Dennt:
Thank you very much for providing that information, it is requested to confirm the system environment in which you are using the application, we really appreciate that.
At this point we will do further research on this case, in order to provide the most accurate response about if it is possible to add command line into download package.
As soon as I get any updates, I will post all the details on this thread.
Alberto
Hi, Dennt, I just received some updates in regard to the research we are doing on this matter. And we just wanted to know if you could please explain how are you trying to do the connection using the One Time Use client?
The way that it is meant to work is, after you enable the guest access plug-in an external person that does not have access to the corporate network can connect to the Unite hub through a virtual access point which is created by that guest access plug-in, after downloading the One Time Use client from the download page (ip displayed in hub) it should automatically connect only to that specific hub.
Alberto
Dennt, I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Alberto
