Intel Unite® App
Support for the Intel Unite® App
456 Discussions
Plugin Issue in Unite Enterprise 3.1
Community Manager
Hello Intel Team,
There is a plugin issue in our unite enterprise system. The custom plugin which i got from intel can not be use. but the plugin was working well in others unite system.
what is the problem of my intel unite system?
When I debug the HUB, I found below log:
7/7/2017 11:33:20 AM Do Platform Check -
7/7/2017 11:33:20 AM 'BDK9S4CU' loaded Successfully. -
7/7/2017 11:33:20 AM 'GF26S5O5' loaded Successfully. -
7/7/2017 11:33:20 AM 'HSON0MMI' loaded Successfully. -
7/7/2017 11:33:20 AM 'SC7MOICU' loaded Successfully. -
7/7/2017 11:33:20 AM 'U9IB5AW7' loaded Successfully. -
7/7/2017 11:33:20 AM 'XS3DA1HG' loaded Successfully. -
7/7/2017 11:33:20 AM Start RunPlugins: ValidateSku -
7/7/2017 11:33:20 AM BDK9S4CU LoadSmBiosData: Success -
7/7/2017 11:33:20 AM No Corporation-Check required. -
7/7/2017 11:33:20 AM Checking Type-11 tables -
7/7/2017 11:33:20 AM Error Running 'BDK9S4CU' Plugin: SMBios missing data: Product-Check not found. -
7/7/2017 11:33:20 AM GF26S5O5 LoadSmBiosData: Success -
7/7/2017 11:33:20 AM Checking Type-1 tables -
7/7/2017 11:33:20 AM Error Running 'GF26S5O5' Plugin: SMBios missing data: Corporation-Check not found. -
7/7/2017 11:33:20 AM HSON0MMI LoadSmBiosData: Success -
7/7/2017 11:33:20 AM Error Running 'HSON0MMI' Plugin: SMBios missing data: Corporation-Check not found. -
7/7/2017 11:33:20 AM SC7MOICU LoadSmBiosData: Success -
7/7/2017 11:33:20 AM Error Running 'SC7MOICU' Plugin: SMBios missing data: Product-Check not found. -
7/7/2017 11:33:20 AM U9IB5AW7 LoadSmBiosData: Success -
7/7/2017 11:33:20 AM Error Running 'U9IB5AW7' Plugin: SMBios missing data: Corporation-Check not found. -
7/7/2017 11:33:20 AM Plugin Manager - Loading assembly ... C:\Program Files (x86)\Intel\Intel Unite\Hub\Plugins\UniteHubVolumePlugin.dll -
7/7/2017 11:33:20 AM Error loading plugin ... - Exception has been thrown by the target of an invocation.
7/7/2017 11:33:20 AM Plugin Manager - LoadPlugins method done -
Community Manager
Hello sdh1984,
Please let me review this matter, I will update the thread as soon as possible.
Amy C.
Ronny_G_Intel
Community Manager
Hello /thread/116071 sdh1984,
I work for Intel Customer Support and I would like to help you with this issue but I need some extra information.
Can you tell me what is the plugin name and what is it for? Also, you mentioned that this is a "custom" plugin, have you tried contacting the person you got it from?
Ronny G
Community Manager
Sorry for I misunderstand, i got the kit from intel, not plugin.
