I have a problem with Intel Unite HUB application.
The application doesn`t show a PIN code.
Only dashes.
The error:
Application_DispatcherUnhandledException Obiekt docelowy wywołania zgłosił wyjątek.Odwołanie do obiektu nie zostało ustawione na wystąpienie obiektu. - Obiekt docelowy wywołania zgłosił wyjątek.
Application_DispatcherUnhandledException w System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandleInternal& ctor, Boolean& bNeedSecurityCheck)
Could any one please help me with this problem?
The Intel Unite HUB is running in Enterprise mode.
The HUB model: Intel NUC7i5DNKE
The Intel Unite Software verision is 3.3.
The server, hub are all connected in the same network.
The firewall is disbaled, on the Server and on the Hub.
I will be grateful for any help.
- Bartosz
Hello LeoC,
Thank you for your reply.
• Can you access the admin web portal from the HUB?
Yes, I can access the admin web portal form the HUB.
• Have you configure the DNS service record?
Yes, the DNS service record for Intel Unite Server is created.
• Do you have a certificate installed on the environment that is SHA 2?
No, I don`t. SHA1 "SelfSigned" cerificate is added on IIS for https bindings.
To ommit the problem with SHA2 cerificate I added to the HUB registry below keys.
"AllowInsecureCertificates"=dword:00000001
"DisableCheckCertificateChain"=dword:00000001
That solves the problem with the lack of SHA2 certificate (error: Blocking Insecure Certificate: SHA1_RSA in debug mode).
Regarding configure the Ccservice.asmx file - there is no such file on HUB. I createdsuch file but it doesn`t solve the problem.
- Bartosz
Hello Leonardo,
I created SHA256 self signed certificate in PowerShall. And added to both on the server and on the Hub.
After this, it works properly, Hub is connecting with the Server, the Server sees connected Hub.
Now I`m strugling with Guest Access plugin and I have some problem with getting it work.
Are you able to help me with the Guest Access also?
Thanks!
- Bartosz
Hello BMatu
Thank you for the information.
I am glad to hear the issue was solve by using the SHA2 certificate.
In order to look into the guest access plugin please go to the following, consult the Windows* event log (event viewer) and provide me with the log file.
What version of guest access are you installing on the environment? please provide me with the download link?
Hope this helps.
Leonardo C.
Under Contract to Intel Corporation
Leonardo,
Unfortunatelly I had to return the Intel NUC computer I got for testing.
Now I`m waiting for purchasing the device.
Then I`ll be able to continue with testing Guest Access.
I will test it in Intel Unite ver. 3.3.
Thank you,
Bartosz
Leonardo,
This week my supervisor will apply for acceptance of costs.
Costs for a screen/projector and the Intel NUC device.
So I think that I will be able to go on with testing at the end of the next month.
Bartosz
