Intel Unite® App
Gain crucial understandings of the Intel Unite® App
This product has been discontinued. This board is currently read only and no longer accepting new posts. Learn more
459 Discussions
Problems with Microsoft Teams Plugin
FFern4
Hi
I have installed the latest version of Microsoft Teams plugin, but I am not able to do it work properly.
What happens is the following:
I invite the hub to a meeting.
The invitation is accepted by the hub.
The meeting appears in the hub when Intel Unite app is running
The button in the hub to join the meeting doesnt work. The colour of the button seems as the option is not available
In the client side, no meeting available appears when clicking in the Teams plugin button
SW versions are:
Hub and client: 4.2.34014
Intel Unite® Plugin for Exchange Calendar Reader - 2.6.490.0
Intel Unite® Plugin for Microsoft Teams - 1.1.1372
Intel Unite® Plugin for Schedule View - 1.1.728.0
OS: Windows 10 Pro spanish, either hubs as clients
Outlook server: Office 365
Microsoft Teams: 1.4.00.22472
surveys disabled at Microsoft Teams in the hub
Fernando
Leonardo_C_Intel
Hello FFern4
Thank you for posting in the Intel Community.
We understand that you are having problems with the Intel Unite® Plugin for Microsoft Teams can you let us know if this was working properly at some point, and what changes were done on the environment when this issue starting happening.
Leonardo C.
FFern4
Hi
It seems the problem is related with the language of Windows 10 in the hub.
I have installed the hub SW in a Windows 10 PC with english language (I was testing with spanish language). In this case, the hub shows the following
It shows the available meetings in two ways:
  • Intel Unite Plugin for Microsoft Teams: Not showed when the hub uses spanish language. It allows the hub to join the meeting
  • Intel Unite Plugin for Exchange Calendar Reader: Also showed when Windows use spanish language. It doesnt allow the hub to join the meeting. It appears as i have activated the option "Enable fullscreen messages" in the server configuration, at the "Intel Unite® Plugin for Exchange Calendar Reader" Options
It seems there are no differences in the client side when changing the language. If the client is in english but the hub in spanish, the available meetings don´t appear either
If the hub is in english, the meeting appear when the client is in english or spanish
When the meeting is launched, at the client side only the "hang-up" option is available. I suppose that some other options should be available (switch on/off the microphone, etc)
Finally, one more comment: when you try to launch the meeting from the client, sometimes the hub is unable to join the meeting (mainly using the spanish client). When you retry once or twice, the hub joins the meeting
Fernando Fernández
eetings availables
