Intel Unite® App
Gain crucial understandings of the Intel Unite® App
459 Discussions
Remoção ou alteração de cor do rodapé da tela
JQuei
Srs, boa noite
Preciso por gentileza de orientações em como proceder para remover a barra azul no rodapé da tela ou alterar a cor. As cores atuais são usadas por nosso concorrente e precisamos é extremamente necessário que tenhamos essa alteração. Estamos hoje com 50 HUB e caminhando para 100 HUBs.
Grato
Jefferson
Hello Jeffsolutions,
Thank you for posting your inquiry regarding our Intel ® Unite App; it will be more than a pleasure to assist you.
Let us investigate further on your request; I will reach you back as soon as we can.
In the meantime, can you please provide us with the Intel ® Unite version that you are running?
Are you using any plugin?
I hope to hear from you soon.
Diego S.
JQuei
Ola,
Obrigado pelo retorno
Segue informações
Enterprise
Unite Server 3.13
Intel Unite HUB 3.2.82.42
Intel Unite® Plugin for Protected Guest Access 3.2.82.42
Thank you for your response.
We will keep you posted.
I hope this helps.
Diego S.
Thank you for your patience.
I regret to inform you that this can't be done on the app as it is not an allowed change due to the branding of the company.
My apologies for the inconvenience that this may cause.
Diego S.
