Intel Unite® App
Gain crucial understandings of the Intel Unite® App
This product has been discontinued. This board is currently read only and no longer accepting new posts. Learn more
459 Discussions
Share Files plugin not found
sk27
I am working on Intel Unite Enterprise plugin development. The set up is done successfully on NUC 7 gen. When the apps (both client and hub) are run, it is working well and my plugins are perfectly deployed. But I don't find Share Files plugin in the Unite Client home screen.( I think it should be a default plugin)
While doing the Unite enterprise setup, after the hub installation, I didn't find any Plugins folder. So I created one and used it to deploy my plugins.
Is it because of this?
Please tell me how can I get that share files plugin or from where can I download it?
Srujana K
Hi srujana k: We will be more than glad to assist you with this matter.
Just to make sure, did you enable the "Allow File Transfer" option on the Admin Portal Home Page menu? We recommend to do that for the application to work properly.
On the link below you will see where that option is located, page 48:
https://www.intel.com/content/dam/support/us/en/documents/software/software-applications/Intel_Unite_Enterprise_Deployment.pdf https://www.intel.com/content/dam/support/us/en/documents/software/software-applications/Intel_Unite_Enterprise_Deployment.pdf
Alberto R
Alberto R
sk27
Hi Alberto R,
Thank you. It worked!!
Srujana K
Hi srujana k, You are very welcome. Perfect, excellent, it is great to hear the application is now working properly.
Any other inquiry, do not hesitate in contact us again.
Alberto R
