Intel Unite® App
Gain crucial understandings of the Intel Unite® App
459 Discussions
Start Guest Access Failed[There is a error start guess access] on Enterprise HUB
Hello Unite Team,
There is a error happened when I start the guest access. the error is [There is a error start guess access].
After check I found below debug log, what's mean?
9/26/2017 9:30:32 PM Client: Got Response: CMD=Unknown; Success=False; errorMessage= - Status: CreatedStart...Done.publisher status change: Aborted -
9/26/2017 9:30:32 PM There was an error starting Guest Access: - Status: CreatedStart...Done.publisher status change: Aborted -
9/26/2017 9:28:14 PM Plugin Manager - Loading assembly ... C:\Program Files (x86)\Intel\Intel Unite\Hub\Plugins\GuestAccessClientPlugin.dll -
9/26/2017 9:28:34 PM Loaded Plugin: Guest Access Plugin -
9/26/2017 9:28:34 PM Plugin Manager - Loading assembly ... C:\Program Files (x86)\Intel\Intel Unite\Hub\Plugins\MetricsPlugin.dll -
9/26/2017 9:28:34 PM Loaded Plugin: Metrics -
9/26/2017 9:28:34 PM Plugin Manager - Loading assembly ... C:\Program Files (x86)\Intel\Intel Unite\Hub\Plugins\TestUnitePlugin.dll -
9/26/2017 9:28:34 PM Loaded Plugin: -
9/26/2017 9:28:34 PM Plugin Manager - LoadPlugins method done -
9/26/2017 9:28:34 PM Plugin Load Complete -
9/26/2017 9:28:34 PM Plugin Manager: Calling LoadEvent for all plugins -
9/26/2017 9:28:34 PM Plugin Loaded -
9/26/2017 9:28:34 PM Client: Connecting and sending stop command -
9/26/2017 9:28:34 PM SizeChanged Right: Screen-> 1600Window-> 1600 -
9/26/2017 9:28:34 PM SizeChanged Bottom: Screen-> 900Window-> 904 -
9/26/2017 9:28:34 PM SizeChanged Bottom: Screen-> 900Window-> 900 -
9/26/2017 9:28:34 PM Client: Got Response: CMD=Unknown; Success=True; errorMessage= - -
9/26/2017 9:28:34 PM Metrics Collection Plugin URI = https://45.117.20.191/Unite/CCService.asmx https://45.117.20.191/Unite/CCService.asmx -
9/26/2017 9:28:34 PM Metrics Collection Plugin Loaded. -
9/26/2017 9:28:34 PM Plugin Manager: LoadEvent Complete -
9/26/2017 9:28:34 PM Slow Init - Plugin init complete -
9/26/2017 9:28:34 PM Certificate Creation Started -
9/26/2017 9:28:34 PM ContentRendered Right: Screen-> 1600Window-> 1600 -
9/26/2017 9:28:34 PM ContentRendered Bottom: Screen-> 900Window-> 900 -
9/26/2017 9:28:35 PM UPLOADING: HubStart Len:00:00:00 -
9/26/2017 9:28:35 PM Upload Successfull. -
9/26/2017 9:28:36 PM Certificate Ready -
9/26/2017 9:28:36 PM Starting RX listeners -
9/26/2017 9:28:36 PM RX Slow Init Complete -
9/26/2017 9:28:36 PM Pin Checkin Success: 439-811 -
9/26/2017 9:29:57 PM CFCRX Incoming connection -
9/26/2017 9:29:57 PM CFCRx Service Ready -
9/26/2017 9:29:57 PM CFCRX Start TLS -
9/26/2017 9:29:57 PM CFCRX TLS Established -
9/26/2017 9:29:57 PM ModeratedMode: Unmanaged -
9/26/2017 9:29:57 PM Telemetry: Hub_UserConnect -
9/26/2017 9:29:57 PM Plugin User Connect -
9/26/2017 9:30:07 PM Plugin Received UI Event: 00000000-0000-0000-0000-000000000010 -
9/26/2017 9:30:07 PM Sending start command -
9/26/2017 9:30:07 PM Guest Access SSID: MeetingroomVC02 -
9/26/2017 9:30:07 PM Guest Access PSK: 43135679 -
9/26/2017 9:30:07 PM Client: Connecting and sending start command -
9/26/2017 9:30:32 PM Plugin Received UI Event: 00000000-0000-0000-0000-000000000010 -
9/26/2017 9:30:32 PM Sending start command -
9/26/2017 9:30:32 PM Guest Access SSID: MeetingroomVC02 -
9/26/2017 9:30:32 PM Guest Access PSK: 43135679 -
9/26/2017 9:30:32 PM Client: Connecting and sending start command -
9/26/2017 9:30:42 PM Client: Got Response: CMD=Unknown; Success=False; errorMessage= - Status: CreatedStart...Done.publisher status change: Aborted -
9/26/2017 9:30:42 PM There was an error starting Guest Access: - Status: CreatedStart...Done.publisher status change: Aborted -
9/26/2017 9:30:42 PM Plugin Received UI Event: 00000000-0000-0000-0000-000000000010 -
9/26/2017 9:30:42 PM Sending start command -
9/26/2017 9:30:42 PM Guest Access SSID: MeetingroomVC02 -
9/26/2017 9:30:42 PM Guest Access PSK: 43135679 -
sdh1984: Thank you very much for contacting the Intel® Unite™ app communities. We will do our best in order to try to fix this problem.
We will do further research on this scenario, as soon as I get any updates I will post all the details on this thread.
Any further questions, please let me know.
Alberto R
sdh1984: I just received an update on this matter and there are some steps we can try in order to try to fix this problem:
-Please go to the directory C:\Program Files (86x)\Intel\IntelUnite\Hub\Plugins
-Once there look for the Guest Access dll and click on properties
-Go to the digital signature tab
-In the Certificate dialog box, click the Details tab
-In the list of fields, scroll to and select Thumbprint
-In the lower pane, the hexadecimal string that is the SHA-1 hash of your certificate is displayed. Select the SHA-1 hash, and then press the Windows keyboard shortcut for the Copy command (CTRL+C) to copy the hash to the Windows clipboard
-Go to the Unite admin website
-Login to your profile and go under groups and select the profiles tab
-Using the profile set for the hub click on the view details button to the right
-Click con Add Profile Property and add the information as below:
Key: PluginCertificateHash_GuestAccessPlugin
(The format is PluginCertificateHash_XXXX, where X is the name you are
giving the plugin)
Data Type: String
Unit: Text
Value: Paste the value saved in the notepad or text file mentioned in
section - Obtaining the Certificate Hash Value - (Thumbprint value). This data can also be entered after creating the key.
-Click on Save
Additionally, on the link below you will find a document for further information including firewall exceptions:
https://www.intel.com/content/dam/support/us/en/documents/software/software-applications/Intel_Unite_GuestAccessPlugin_Guide.pdf https://www.intel.com/content/dam/support/us/en/documents/software/software-applications/Intel_Unite_GuestAccessPlugin_Guide.pdf
Alberto R
Hi Alberto
Thanks for reply.
I have cheack the guest admin document many times. I'am sure I have followed this but no change.
Below is the HUB System event LOG
Guest Access Service Error Processing Message: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host. at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) at GuestAccessLib.StreamHelper.ReadObject(Stream stream, Type type) at GuestAccessLib.ServiceListener.ProcessStream(Object s)
sdh1984: Thank you very much for letting us know those details.
We will continue with our research on this subject. As soon as I get any updates I will post them on this thread.
Alberto R
system event log
