Intel Unite® App
Support for the Intel Unite® App
The Intel sign-in experience is changing in February to support enhanced security controls. If you sign in, click here for more information.
457 Discussions
TXT Record and SRV Record
LShum2
Hi there,
We are trying to configure Intel Unite’s TXT Record for the auto provisioning of the clients. However, our Network team suggested that the debug log that we saw below from the client’s app is searching for SRV record, which have not documented on the user manual. Is there something that we are not aware of?
We would like to create a ticket so that we can CC our Network team on the conversations, thank you.
[Info] AppDelegate: Server is uniteservice.zzzzz.xxxxx.ca
Searching for uniteservice.zzzzz.xxxxx.ca
Searching for _uniteservice._tcp.zzzzz.xxxxx.ca
Searching for _uniteservice._tcp.xxxxx.ca
Searching for uniteservice.xxxxx.ca
Changing search domain to .xxxxx.ca:
[Info] AppDelegate: Server is uniteservice.xxxxx.ca
Wanner_G_Intel
Hello LShum2,
Thank you for submitting your question on this Intel® Community.
To better assist you, what is the Intel Unite® App version you are running?
Wanner G.
A Contingent Worker at Intel
LShum2
Hi Wanner,
Our version is 4.0.4173.30 for both Hub and Clients.
Environment (office, enterprise, school, hospital, factory, home):
School
HUB/Client computer details:
HUB manufacturer(s): Dell
HUB model(s) and SKU: OptiPlex 7050 Micro, I can DM you directly if you need the SKU
Windows OS (provide Version number if Win10, and 32- or 64-bit) and update version:
HUB - Windows 10 Enterprise 64-bit version 1903, build 18362.295
Intel Unite® Server version: Windows Server 2016
Thank you,
Levin
Wanner_G_Intel
Hello LShum2,
Thank you for your response.
First, we would like to know if you created the DNS TXT Record based on section 4.5 DNS TXT Record of the Intel Unite® Solution version 4.0 Deployment Guide (Pag 32).
If the issue persists, please attach the following log files.
  • "intel unite launcher.exe" /debug >log_output.txt
Is there an alternative method?
Create a folder on c:\ drive so the log can be kept in storage.
C:\UniteLogs\ and add the following registry key:
HKEY_LOCAL_MACHINE\software\Intel\Unite\ LogFile (String)
Specify the file path as well as the name for your log files on the string value:
C:\UniteLogs\logs.txt
Files name are IntelUniteServerLog.txt, IntelUniteTransactionLog.txt, and UniteServerLog.txt
  • The Client and Hub logs are created by default and are called Unite.sql.
This file is located at C:\Users\User\AppData\Local\Temp
This file is a SQLite database, and it can be opened with any SQL Client but the DB Browser for SQLite is recommended.
Find all data generated by the application on the table, Logging.
  • Generate a system report with the Intel® System Support Utility (Intel® SSU) and attach it to this thread.
  1. Intel® SSU Download link
  2. Open the application and click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
  3. Click on the menu where it says "Summary" to change to "Detailed View".
  4. To save your scan, click on "Next", then "Save".
Wanner G.
LShum2
Hi Wanner,
Our network department created the DNS TXT record as per section 4.5 on the deployment manual. They mentioned that they have created it in the top level domain.
Can we send you the logs by email but not posting it on the forum because the forum opens to public?
Thank you.
Levin
Wanner_G_Intel
Hello LShum2,
We will send you an email to the email address associated with your profile.
Please reply to this email at your earliest convenience.
Wanner G.
Wanner_G_Intel
Hello LShum2,
Were you able to collect the log files requested to better assist you?
If you need further assistance, please let us know. We will be glad to assist you.
Wanner G.
Wanner_G_Intel
Hello LShum2,
We would like to know if you are still having the issue reported.
It is worth mentioning that Intel Unite solution 3.x uses a DNS SRV record for Autodiscover, while Intel Unite solution 4.0 uses a DNS TXT record. This allows both to run within an organization.
Now, are you referring to the Auto Pairing mentioned on the Intel Unite® Deployment Guide?
Wanner G.
Wanner_G_Intel
Hello LShum2,
If you need any further assistance, please let us know.
Wanner G.
Wanner_G_Intel
Hello LShum2,
We have not heard back from you, so we will close this inquiry. If you need further assistance, please post a new question.
Wanner G.
