Intel Unite® App
Support for the Intel® Unison™ app
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
456 Discussions
The server does not respond
JSmit43
I have installed Intel Unite Enterprise server onto a VM with Server 2012 Standard R2 and SQLExpress. ASP.NET and .NET Framework 4.5 are also installed along with IIS. The Admin portal opens and I get a login however it will not login and gives the error "The server does not respond". I have installed Unite version 3.1.32.12.
Thank you,
Jason
Community Manager
Hello Jason@Mohawk,
Please let me review this matter, I will update the thread as soon as possible.
Amy C.
JSmit43
Thank you Amy C.
I am attempting to setup the Enterprise Solution for the first time. So far I must say it hasn't been the smooth implementation. I appreciate any help you have to offer.
Thank you,
Jason
Community Manager
Thanks to you Jason.
I would like to confirm a couple of things, please see below;
1. Verify the Web Service installation was successful, following the link: https:///unite/ccservice.asmx
  • Select GetProfile.
  • Enter test in the value field and press invoke
Page 14 of the Intel® Unite™ Solution Enterprise Deployment Guide will give you a better look.
2. Add Roles and Features to the server using
  • Server manager
    • Server Roles: Web Server
  • Include Management Tools
  • Add .NET Framework 3.5 features
  • Add .NET Framework 4 features
    • ASP .NET
      • WCF Services
      • HTTP Activation
    • Web Server Roles:
      • Web Server, Common HTTP features and Default Document.
3. Confirm if able to see the "UniteServer" database by accessing to SQL Server Management Studio.
Find the Intel® Unite™ Solution Enterprise Deployment Guide here: http://www.intel.com/content/dam/support/us/en/documents/software/software-applications/Unite%203.0%... http://www.intel.com/content/dam/support/us/en/documents/software/software-applications/Unite%203.0%...
Amy C.
Community Manager
Jason, hope you were able to check my previous input.
Amy C.
BvanW
Hello Amy C.
I have the same problem, if i put test in the asked value field then it generate this page:
System.Data.SqlClient.SqlException: Login failed for user &# 39;UniteServiceUser&# 39;.
at System.Data.SqlClient.SqlInternalConnectionTds..ctor(DbConnectionPoolIdentity identity, SqlConnectionString connectionOptions, SqlCredential credential, Object providerInfo, String newPassword, SecureString newSecurePassword, Boolean redirectedUserInstance, SqlConnectionString userConnectionOptions, SessionData reconnectSessionData, DbConnectionPool pool, String accessToken, Boolean applyTransientFaultHandling)
at System.Data.SqlClient.SqlConnectionFactory.CreateConnection(DbConnectionOptions options, DbConnectionPoolKey poolKey, Object poolGroupProviderInfo, DbConnectionPool pool, DbConnection owningConnection, DbConnectionOptions userOptions)
at System.Data.ProviderBase.DbConnectionFactory.CreatePooledConnection(DbConnectionPool pool, DbConnection owningObject, DbConnectionOptions options, DbConnectionPoolKey poolKey, DbConnectionOptions userOptions)
at System.Data.ProviderBase.DbConnectionPool.CreateObject(DbConnection owningObject, DbConnectionOptions userOptions, DbConnectionInternal oldConnection)
at System.Data.ProviderBase.DbConnectionPool.UserCreateRequest(DbConnection owningObject, DbConnectionOptions userOptions, DbConnectionInternal oldConnection)
at System.Data.ProviderBase.DbConnectionPool.TryGetConnection(DbConnection owningObject, UInt32 waitForMultipleObjectsTimeout, Boolean allowCreate, Boolean onlyOneCheckConnection, DbConnectionOptions userOptions, DbConnectionInternal& connection)
at System.Data.ProviderBase.DbConnectionPool.TryGetConnection(DbConnection owningObject, TaskCompletionSource`1 retry, DbConnectionOptions userOptions, DbConnectionInternal& connection)
at System.Data.ProviderBase.DbConnectionFactory.TryGetConnection(DbConnection owningConnection, TaskCompletionSource`1 retry, DbConnectionOptions userOptions, DbConnectionInternal oldConnection, DbConnectionInternal& connection)
at System.Data.ProviderBase.DbConnectionInternal.TryOpenConnectionInternal(DbConnection outerConnection, DbConnectionFactory connectionFactory, TaskCompletionSource`1 retry, DbConnectionOptions userOptions)
at System.Data.ProviderBase.DbConnectionClosed.TryOpenConnection(DbConnection outerConnection, DbConnectionFactory connectionFactory, TaskCompletionSource`1 retry, DbConnectionOptions userOptions)
at System.Data.SqlClient.SqlConnection.TryOpenInner(TaskCompletionSource`1 retry)
at System.Data.SqlClient.SqlConnection.TryOpen(TaskCompletionSource`1 retry)
at System.Data.SqlClient.SqlConnection.Open()
at CCService.GetProfile(String fqdn)
Maybe you can help me with the problem.
I have followed the installation guide and everything is created in the SQL server, as asked from the guide.
Brecht
BvanW
I found the solution, here is the link:
https://www.lansweeper.com/kb/23/SQLserver-enable-mixed-authentication.html Configuring an existing SQL instance to host the Lansweeper database
Brecht
Community Manager
Thank you for sharing this link Brecht.
Amy C.
