Hello sdh1984,
Thank you for contacting Intel Communities.
In this case, since the USB PIR is not a required component to deploy the Intel® Unite™ software, there isn't a recommended brand or model that we can provide.
In addition to this, the software can be also installed on 3rd party devices; therefore, you may find some other compatible products to the hardware you are using.
With this being said, you can get a USB PIR based on your needs or system requirements.
Hope this information helps.
Juan Carlos
Hello sdh1984,
Juan Carlos
Topic Options
