Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
USB PIR(Passive infrared)motion sensor
Jump to solution
Any recommend brand or model of USB PIR(Passive infrared)motion sensor to intergrated with Intel unite meeting enviroment?
PS: i found this intergration information in the attached official intel unite deployment document, Page 4.
Accepted Solutions
Community Manager
Hello sdh1984,
Thank you for contacting Intel Communities.
In this case, since the USB PIR is not a required component to deploy the Intel® Unite™ software, there isn't a recommended brand or model that we can provide.
In addition to this, the software can be also installed on 3rd party devices; therefore, you may find some other compatible products to the hardware you are using.
With this being said, you can get a USB PIR based on your needs or system requirements.
Hope this information helps.
Juan Carlos
Community Manager
Hello sdh1984,
Juan Carlos
