Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Unite Web Portal Loading Slow Issue
Hello Unite Team,
Here is an issue that the unite web portal loading slow when I open it. it may be takes 2 minutes, and the https://localhost/admin https://localhost/admin has the same issue.
it's this cause of google web? Here is China, We can't open any google Web. it seems check google url first.....
Unite server v3.2
Community Manager
Hello sdh1984,
I understand that your Intel ® Unite web portal is loading really slow and takes up to 2 minutes to load the admin portal.
Since you mention that the webpages are not accessible then it could be related to a network issue, however before jumping into that conclusion I will need to know the version of Intel ® Unite that you are running. Is it the enterprise or the stand alone?
Also, please provide us with the model of the clients, server and hub.
David V
Community Manager
Its resolved as below:
Oepn C:\Program Files (x86)\Intel\Intel Unite\AdminWebPortal\js\main.js
Replace https://www.google.com/jsapi?q=1 https://www.google.com/jsapi?q=1 with ./jsapi
Replace https://www.gstatic.com/charts/loader https://www.gstatic.com/charts/loader with ./loader
Claudio_G_Intel1
Hi, correct Unite 3.x requires uses the google services URL in order to display/gather info for the telemetry graphics.
https://www.intel.com/content/www/us/en/support/articles/000023228/software.html Telemetry Plugin Guide for the Intel Unite® app
Unite 4.0 no longer has this requirement.
Edited answer to answer customer question.
