Intel Unite® App
Support for the Intel® Unison™ app
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
456 Discussions
Unite client can't connect to unite hub
mchak3
I had used unite Hub and unite client with intel Unite cloud. I already pairing hub and register client with intel unite cloud.
Unite hub already working and show pin for connecting.
I put pin to client but it can't connect. It show error "unable to establish a connection".
After that it show error "The pin you entered could not be found, please try again."
what is the problem? How can I solve it?
mchak3
This is log data, Can anyone help me.?
08/06/2562 7:27:00 Info - [RangerHelper] At PinLookUp: {
 "code": 200,
 "success": true,
 "data": {
   "listenPort": "50024",
   "certificateHash": "30da6447a25cd1db3f7a1efd0578844e25eea3421fa771febb43406ab23be4c5",
   "certificateAlgorithm": "Sha256",
   "renewCurrentPIN": "True",
   "hostname": "DESKTOP-M1BL87K",
   "ipAddresses": [
     "172.21.133.251"
08/06/2562 7:27:00 Info - [ClientTcpRangerConnectionModule] Pin found at V4 or upper
08/06/2562 7:27:00 Debug - [ClientTcpRangerConnectionModule] At Connect, hub properties: 172.21.133.251, 50024, 30da6447a25cd1db3f7a1efd0578844e25eea3421fa771febb43406ab23be4c5
08/06/2562 7:27:00 Info - [ClientTcpRangerConnectionModule] At Connect, TcpClient begin async connection request
08/06/2562 7:27:21 Info - [ClientTcpRangerConnectionModule] At OnSocketConnect, end pending async connection attempt
08/06/2562 7:27:21 Info - [ClientTcpRangerConnectionModule] Saved key PinPadWindow of type DWord with value 1 in CurrentUser at SOFTWARE\Intel\Intel Unite\Client
08/06/2562 7:27:21 Error - [ClientTcpRangerConnectionModule] EXCEPTION: At OnSocketConnect, unable to establish socket connection with the Hub. - A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond 172.21.133.251:50024
  at System.Net.Sockets.Socket.InternalEndConnect(IAsyncResult asyncResult)
  at System.Net.Sockets.Socket.EndConnect(IAsyncResult asyncResult)
  at System.Net.Sockets.TcpClient.EndConnect(IAsyncResult asyncResult)
  at Intel.Unite.Windows.Core.Connection.Client.ClientTcpRangerConnectionModule.OnSocketConnect(IAsyncResult ar)
08/06/2562 7:27:21 Debug - [ClientTcpRangerConnectionModule] Closing Socket...
08/06/2562 7:27:31 Debug - [ClientTcpRangerConnectionModule] Closing Socket...
08/06/2562 7:27:31 Info - [ClientTcpRangerConnectionModule] Saved key PinPadWindow of type DWord with value 1 in CurrentUser at SOFTWARE\Intel\Intel Unite\Client
Wanner_G_Intel
Hello mchak3,
Thank you for posting on this Intel Community.
We will review this information and get back to you soon.
Wanner G.
Under Contract to Intel Corporation
RPabi
I'm having the same issue what was the resolution?
