I'm an MSP and when I saw the new vPro Compute Stick, I thought 'this is exactly what I was waiting for' so I could use Unite in my office and take it on the road to demo to clients.
So I just installed the 2.0 version from the MSP site download, and it _doesn't_ install. It goes through the process and at the end it briefly shows 'rollback' and ends with a dialog that says "The Intel Unite Software Setup Wizard ended prematurely because of an error. Your system has not been modified. To install this program at a later time, run Setup Wizard again. Click the Finish button to exit the Setup Wizard."
And that's it. No logs to look at (that I know of), and no direction on what to do.
$600+ cost from Synnex Canada for this little puppy, and would _really_ like to use it for the reason I bought it.
At IT Nation last year, the Unite presentation folks said it will work on any system with vPro.
What am I doing wrong?
David Lee
DigiVie
- Tags:
- Intel® Compute Stick
David,
I'm from Intel's Unite team.
Thanks for your interest in Unite and Intel compute stick! You are definitely an early adopter!
We are currently working on a Unite version 3.0 that will be available in mid-July that will work on Intel's vPro compute stick.
We are currently working on final validation on a variety of compute sticks, OEM systems, etc.
Unite versions 1 and 2 do not work with Intel's vPro compute stick.
Rhett
David,
Rhett
Hey Rhett,
Ok, so I feel better now
Need a beta tester?
I'd also be trying to make this work from a LAN to a wifi subnet on a Sonicwall in Standalone mode - hopefully that's on the feature list for 3.0! Being able to do this would certainly make the solution a lot more saleable in the SMB market.
Cheers,
David
David,
Yes, we have a beta testing program we're working on in July.
You can send an email to Eric Townsend (mailto:eric.townsend@intel.com eric.townsend@intel.com) or Scott Schafer (mailto:scott.schafer@intelmsp.com scott.schafer@intelmsp.com) to get information on the Unite 3.0 trials.
Thanks for your interest!
Rhett
