I just want to create a small business Intel Unite because it is easier than Enterprise business, but I'm not sure what function it can come true? Who know this could help tell me ?
Hello @Alex666.
We will move your question to the correct subforum, the team in charge will get back to you soon.
Jean O.
Hello Alex666,
Thank you for contacting Intel Customer Support.
We understand that you need information in regard to the Intel Unite(R) Small Business solution. I will be more than glad to help you today.
You can find information on how to set up the Intel Unite Small Business solution by checking this user guide:
You can also check:
Please let us know if the information above was able to answer your questions, or if you require additional assistance.
Sergio S.
Hello Alex666,
We are following your case and would like to know if the information provided earlier was able to answer your question.
Sergio S.
Hello Alex666,
We are following your case and would like to know if you need more assistance or if we can close this thread.
Sergio S.
Hello Alex666,
We are following up further on this case, which is still open with a "what function can be come true if I install Intel Unite with a small business?" problem description.
We know that this is important for you to get it resolved and it is also equally important for us to get you the right solution. Since we have not seen an update for a week, now, please, know we will get in contact with you next Thursday March 25th to inform you that the thread will be closed; this is if there is still no answer from your side, by then.
Sergio S.
Hello Alex666,
This message is to inform you that we are going to close this thread.
Sergio S.
