5225 Discussions
About Intel Black Box for common redundant power supply format question.
AChen97
Hello ,
I reading the CRPS design guide about PMBus Black box Command
The meaning as below:
Format: Read Block with PEC (238 bytes)
Code: DCh
The content have "System Tracking Data(47 bytes)" and "Power supply event data(38 byte per event)",
and the "Power supply event " can record 5 event,
so.. the total length of the command as 47 bytes + (38 bytes *5 ) = 237 bytes,
I calculated the result with the design guide length is not equal (238 byte ≠ 237bytes),
Is anyone knew the correct format about this command(DCh) , or can tell me what's detail I missed?
Alan Chen,
Thank you for contacting Intel(R) Technical Support.
In an effort to better assist you, can you please indicate to which Intel Product are to trying to apply this command?
Your prompt response is highly appreciated.
regards,
Jeremiah A.
AChen97
Hi Jeremiah,
Thank your reply, and the Intel product I used is S2600 series,
I see the Technical Product Spec for S2600, and found the description as below:
First, I just want know how to decode the "Black Box" command from power supply(CRPS),
and next step I will connect to S2600 mother board.
By the way, Is it have different black box protocol in different mother board?
Many thanks,
Alan Chen.
Hello Alan,
Thank you for your quick response.
I will go ahead and investigate and get back with you as soon as possible with information.
regards,
Jeremiah A.
AChen97
Hi Jeremiah,
If there is any update information,please prompt reply to me.
Alan Chen.
Hello Alan,
I apologize for the inconvenience.
I'm still investigating on your query about the Power Supply Diagnostic Black Box.
In the mean time, can you please provide some more information on why are you trying to decode this command?.
regards,
Jeremiah A.
AChen97
Hi Jeremiah:
I'm a software developer , and I need demo the Black Box function for my boss,
So I need confirm the correct spec and develop the software with a friendly GUI.
regards,
Alan Chen.
Hi Alan,
I hope you are doing well today.
Thank you for your quick response and information. I still investigating your query; I will get back to you with information as soon as possible.
regards,
Jeremiah A.
Hi Alan,
I still investigating your query; I'm checking with engineering about this. Another question I have is: Can you indicate the sever chassis you are going to use?
regards,
Jeremiah A.
AChen97
Hi Jeremiah:
I have no chassis, now I just need decode the black box function,
so I think the chassis is no matter with our query,
Many thanks,
Alan Chen.
Hi Alan,
Thank you for your response.
I was informed that this type of inquiries are assist by a more direct support line. You can contact us via the following line: Phone Number: (916) 377-7000Business Hours:
Monday - Friday
7:00 AM to 5:00 PM (Pacific Time)
regards,
Jeremiah A.
AChen97
Dear Jeremiah:
Thank your fully support ! But I don't called the support contact window,because I can't follow this Business Hours,
I still solved this query , because I got a new power supply and try to decode this command,
The result is 1 byte-Data Length + 47 bytes-Tracking Data + 190 bytes-Event Data = 238 bytes ,
Many thanks and Best regards,
Alan Chen,
Hello Alan,
I'm to hear that you were able to find the information. Please let me know if there is something else we can help you.
regards,
Jeremiah A.
Hello Alan,
I have not herd back from regarding this issue. I will proceed in closing this case.
Thank you for contacting Intel technical Support.
regards,
Jeremiah A.
Intel Technical Support
