5228 Discussions
Ask An Expert - The Server Room
<![CDATA[<font size="3">Welcome to intel.com/ITopia. Join the discussion, debate and collaborate. This is your opportunity to *ask our experts* what you want to know about Intel's latest technologies. The floor is yours.]]><![CDATA[<hr>]]><![CDATA[<font size="2">+This discussion is not intended to answer PC support question. If you have a support question go to {document:id=1086}.+]]>
Please visit http://www.kernel.org/ Linux Kernels.
JLodh
New Contributor II
Linux kernel is continuously updated however based on this kernel, there comes different flavours of Linux all of which use the same kernel with a little, no or major changes. A few of the famous linux distros are;
  • Red Hat
  • Suse
  • Debian
  • Slackware
  • Ubuntu
  • CentOS
  • Gentoo
and the list goes on and on.
However the latest stable version of kernel is 2.6.26 as quoted by http://www.kernel.org/ Linux Kernel Archives dated Jul13, 2008 at 22:44 UTC
For a D955xbk intel motherboard, is there anyway to roll back the voltage and memory speed to it's default settings if it was set in the bios and now will not boot ? Removing the battery does not work.
Please note, this forum is not ment for TS. However, please check for motherboard LED, RAM beeps, processor fan spin. If they are intact then perform a BIOS recovery.
Download the http://downloadcenter.intel.com/T8Clearance.aspx?sType=&agr=N&ProductID=2070&DwnldID=12688&url=/12688/eng/BK2049P.BIO&PrdMap=&strOSs=38&OSFullName=OS Independent&lang=eng .BIO file. Perform http://downloadmirror.intel.com/12688/ENG/BIOS%20Update%20Readme.pdf Recovery BIOS Update. Please find general steps for BIOS Recovery Update http://www.intel.com/support/motherboards/desktop/sb/cs-023360.htm here.
We are trying to get an answer to a relatively simple question….is the x5450 processor monolithic or MCM?
Where can we get the official spec showing whether it is MCM????
x5450 processor monolithic or MCM? (Need official documentation from Intel showing which it is.)
Christophe_P_Intel
Hi, The Xeon 5400 series processors are based on the Penryn (codename) architecture, a 45nm high-k product. This product is an MCM (multi-chip module) where we manufacture the quad-core CPU using 2 side-by-side 45nm dual-cores in a common package, just like we did with the first generation quad core xeon 5300. Here is a http://www.intel.com/technology/architecture-silicon/45nm-core2/index.htm?iid=tech_micro+45nm website where you can explore more and find access to technical whitepapers on intel.com about pernyn and future architectures.
Now, I have a question for you. Why does MCM vs monolithic matter? Can you explain why you are asking the question as I'm curious.
Thanks, Chris
Thanks for the response concerning MCM vs monolithic.
<Why does MCM vs monolithic matter? Can you explain why you are asking the question as I'm curious.>
We are dealing with an Oracle licensing issue. For Oracle Standard and Oracle Standard One, they have different ways of counting cores/processors. A monolithic processor counts as one processor (regardless of number of cores) whereas a MCM processor counts as 2 processors in this case.
Christophe_P_Intel
Thanks for the information. I've been aware of many different software licensing practices and policies in the world of multi-core but this is the first time i have heard that the manufacturing implementation has an impact on licensing. Chris
I would like to get the drivers for Intel PRO 1000/PT Bypass Adapter.
The seller guy told me I was able to get open source related driver.
William_L_Intel1
Thanks for your question. You may want to try this page on http://support.intel.com/support/network/adapter/index.htm Network Connectivity. Let us know if you find the driver you needed.
I'm looking for a desktop/worksation machine with integrated optical audio input & output ports. Or a recommendation for such machine.
I'm in academia and we want this for experiment workstation.
// Sal Aguinaga
// Northwestern University
William_L_Intel1
We have only seen the Intel motherboards with SPDIF optical output (TOSLINK), never inputs and we think most of the OEM workstations don't offer digital outputs or inputs. To accomplish your requirements, you may have to buy a workstation and then a discrete audio card such as this one: http://us.creative.com/products/product.asp?category=209&subcategory=669&product=17791&nav=1 Click Here. Thanks for your question and let us know how it turns out.
I love this Web site!
William_L_Intel1
Thanks. Intel experts are here to answer your server related questions.
I need a good program for pc maintenance, cleaning, deleting unwanted and unserviceable programs anto to maintain my pc s in good condition
William_L_Intel1
Thanks for your question. We couldn't make any specific recommendation, though I'm sure you could find many options on the web if you try a google search.
I try to upgrade my s5000pal to install 2 x Xeon E5430 but with no like. After I install processors, BIOS say mismatch voltage configuration error. How can I solve this problem.
ozvonaryov@lohika.com
William_L_Intel1
Thanks for your question. To better answer your questions, could you please inform us the following information:
CPUID, Speed, Cache size, and Stepping of each processor? (i.e. install one at a time into the platform).
This is all displayed in BIOS Setup->Advanced->Processor -> CPU Info.
Also, What BIOS version are you currently using? We look forward to your reply.
Sir,
I want to open a computer company, at Bangalore India. I don't have any idea how to collect information about products and get register with companies, and how to get the product 4m them. Kindly tell me how to contact intel
William_L_Intel1
Thanks for your question. I am trying to get the contact information for you. Please check back soon for an update.
