Help: Intel Shared LUN
员工
3,737 次查看
Can anyone tell-me what Filesystem can i use to format and use the shared LUN disk, in order to be used in 2 Blades with Debian Lenny?
The ideia is to get 2 apache nodes, using the same storage.
0 项奖励
5 回复数
Daniel_O_Intel
1,614 次查看
The Shared LUN just makes the (virtual) hardware available to both compute modules - it doesn't care what filesystem is on it.
It would be entirely up to the OS, as to what filesystems it supported.
0 项奖励
员工
1,614 次查看
Thanks, yes that i know that.. its on the FAQ page regarding the shared LUN.
My question is specific about the system.
0 项奖励
Daniel_O_Intel
1,614 次查看
Your question is about Debian Lenny, then?
0 项奖励
员工
1,614 次查看
Yes, i´m using Debian Lenny. My question is about what is the best filesystem to be used, that Debian supports, in order to prevent 2 servers to write to the same block causing data corruption.
0 项奖励
Daniel_O_Intel
1,614 次查看
This forum is more for Intel server hardware questions. There's certainly nothing preventing anyone here from helping you out with an OS question, of course; but you may have better results asking on one of the Debian forums out on the net, rather than here.
0 项奖励
回复
