5136 Discussions
How do I add power suppy sensors to S5520UR SDR?
I have a system based on S5520UR board with Delta power supplies. The system is not recognized as an Intel chassis when I do frusdr update and when system is running, IPMI does show any PS sensors. I have manuals for Delta PS with all registers listed, how do I make fdrsdr utility add PS sensors so I can use IPMI system to monitor it?
Daniel_O_Intel
You'd have to edit the SDR directly. Generally, it's easier to just run the FRUSDR utility, and chose "Other" for the chassis.
