Intel® Xeon® Processors, Data Center Products including boards, integrated systems, and RAID Storage
5265 Discussions
Intel Optane M.2 SSD on S2600CW2R
dr3s3l
Hello guys,
I would like to use an M.2 Intel Optane on my S2600CW2R Mainboard.
My problem is that the board does not recognize the ssd.
I have already read that the board only SATA M. 2 SSDs detects what is the case with the Intel Optane. Do I have to change an Option in the Bios?
Greetings
https://www.intel.com/content/dam/support/us/en/documents/server-products/server-boards/S2600CW_TPS.pdf
LeonWaksman
You can't use Optane Memory on your board. The Optane Memory requires M.2 slot with PCIe interface  while the M.2 slot on your board supports only SATA interface.
In addition BIOS must support Optane memory as well: SATA mode should be set to Intel RST Premium with Intel Optane.
Leon
LeonWaksman
Leon
dr3s3l
Ah okay, I thought Optane was SATA because of the connector type.
But this explains a lot.
Thank you for your help.
Dineshbabu
Hi dr3s3l,
Thank you for your response. we are closing this request. Please don't hesitate to ask any further questions in the future.
Feel free to start a new conversation, as this thread will no longer be monitored.
Dineshbabu.
