5132 Discussions
It's possible to downgrade the BIOS on Intel S2600CO server board?
MMigu1
If this is possible I need some advice on how to do it. Thanks.
It is possible but not recommended, How ever if toy still need to do it it's the same process as updating the firmware just run a previous version package.
MMigu1
I already tried that but I'm getting this message:
Error:
BIOS or ME update failure
The capsule file failed in the security compliance check.
Please refer to BIOS release note for details.
MMigu1
A new update. I tried to use a recovery BIOS from a previous version and following the steps for the recovering process I was able to downgrade the version I had, from this point I followed the procedure you suggested and the downgrading process to the version I needed was successful this time.
I'm glad it worked for you.
