5140 Discussions
Motherbord S1200v3RP don't show video
JMend19
I've been trying to make a s1200 motherboard work, but show me a strange combination of led messages that i didn't found in the intel manual.
orange: 0 0 X 0
green : X 0 X X
Status Led: Blink Orange
Tested with:
Processor
Xeon E3-1220
Pentium D3240
Memory
Kingston HX316C10FW/4
Kingston KHX1333C7D3K2
Font
Cooler Master 650W
C3 Tech 650W
You can decode the LED's by using the following website:
http://www.intel.com/support/motherboards/server/sb/CS-034129.htm?wapkw=034129 Server Products — Intel® Server Board POST Code Diagnostics
Regarding compatibility, only the E3-1220 v3 and G3240 are fully compatible with the board. The memory you are using is not compatible with the board so that could be the nature of the issue.
Here are our recommendations:
- Test the system without processor installed looking for a 1-5-4-2 beep code sequence.
- Test the system without memory installed looking for a 3 beep code sequence.
- Make sure to use memory with the following specifications:
ECC Unbuffered DDR3L
Single-channel and dual-channel memory organization modes
Data burst length of eight cycles for all memory organization modes
Memory DDR3 data transfer rates of 1333, and 1600 MT/s
64-bit wide channels
DDR3L I/O Voltage of 1.35 V
JMend19
Thanks for the response
Tests:
1 - Was a little bit different, the beep sequence 1-5-2-1
2 - Ok for the 3 beep code sequence
3 - One question, any ECC memory with this specification will work?
Your affirmation is correct, also here is the list of tested hardware for the board:
http://www.intel.com/support/motherboards/server/sb/CS-034302.htm Server Products — Memory and Hardware Compatibility
