5136 Discussions
R1304RPMSHOR (S1200V3RP) Platform Confidence Test (PCT) Utility for EFI 3060072f error
I have a R1304RPMSHOR (S1200V3RP) server.
The chassis fan is running too fast or too loud
I have download the PCT for EFI, copy it to a USB and follow instructions.
But when I click on "quick test" or "comprehensive test" an error is shown and no test is done:
*** ERROR TX64.EFI 3.22.1.0001 ***
Missing or invalid software license.
Standard Error Code = 3060072F
(Error logged at 08-16-2016 16:18:04)
I have search but I have not found any reason.
Does some know the reason of the error? or a way to solve it?
I will appreciate any help. Thanks a lot
Thank you for contacting Intel Customer Support.
There is a work around for this situation. Change the date in the BIOS, to the 2015. Run the PCT, and test should run fine. Keep in mind, it is always good, to tun the latest firmware update and the latest PCT version.
Please, let us know your results.
faugub_intel # iwork4intel
Coconutdog
Thanks, that worked. Your download site for the S3420GPLX suggests a later version is available which is efi_pctx64_122.zip. This does not work with the S3420GP series of Server Mainboards.
