RMS25CB080 + AXXRPFKSSD2
Hi there,
i got some servers (R2224GZ) with RC RMS25CB080 + AXXRPFKSSD2.
Im able to create VD e.g. RAID 10 etc, but there is no way to create a CacheCade Virtual Drive.
PS : Im using the latest firmware of BIOS and Raidcontroller.
In the WebBios "Managed Advanced Software Options/Features" there is no CacheCade.
Can someone tell me how to enable it?
Thanks alot!
Hello Marco,
If I understand correctly, you are using RMS25CB080 + AXXRPFKSSD2 and you created RAID 10 on Virtual Drive, but not able to create the Cache Cade Virtual drive.
I noticed you mentioned the latest firmware version for the RAID controller. Could you please confirm the version that is running at?
Additionally, I was wondering if could provide a breakdown of the configuration you are using. For instance, how many drives do you have in your RAID 10, and how many SSD drives are you planning to use for the SSD CacheCade?
If possible, please provide us with screenshots of your RAID configuration as shown in the Intel RAID Web Console 2 or WebBios.
Was the virtual drive created before or after installing the key?
If there is anything else we can help please feel free to ask.
Henry A.
Hi Henry,
Yes, right!
Yes, latest Firmware of Controller and BIOS of Board.
Well I created a RAID10 with 12x 600 GB SAS Drives, and 2x SSD (2x256GB) - this works fine. But there is no option to activate / create CacheCade Pro.
I tried it before and at the same time.
Thanks!
Hello Marco,
Thank you for the update. Please provide us with screenshots of your RAID configuration as shown in the Intel RAID Web Console 2 or WebBios.
Henry A.
2x 135GB SAS = RAID1
12x 600GB SAS = RAID10
2x 256 GB SSD for Caching.
Hello Marco,
Thank you for the update. I will check on this because the convination on HDD (SAS and SATA SSD).
Henry A.
Hi Henriy,
im running similar configuration with Raid Controller 9260cv-4i without any problems. Maybe it helps!
Hello Marco,
Thank you for the update. I will gather all the necessary Hardware and run the LAB. Please allow some time and I will get back with you as soon as possible.
Henry A.
Hello Marco,
Thank you for your patience. Could you please be so kind and have tried re-sitting the key. If the issue continues, we would appreciate if you could provide us with the complete log file of the RAID controller. You can use the StorCLI utility to capture it.
https://downloadcenter.intel.com/download/26820/StorCLI-Standalone-Utility?product=60283 https://downloadcenter.intel.com/download/26820/StorCLI-Standalone-Utility?product=60283
Henry A.
can you tell me, how to reset the key?
Your Link isnt working.
Thanks!
You need to remove the jumper key (AXXRPFKSSD2) from the RAID controller and then reinstall it back. For additional information you can refer to the http://www.intel.com/content/dam/support/us/en/documents/motherboards/server/sb/g29824001_axxrpfkssd2_axxrpfkde2_axxrpfksnsh2_ig.pdf Intel(R) RAID Premium Feature Keys Installation Guide.
I checked the link and it is possible that we do not have the equivalent link for your region. Try to go to the link again, once it gets to the Intel page go ahead and chance the location to America > United States.
Let us know if this helps
Jeremiah A.
I'm following with you to see if the information provided help or if you need more assistance with the issue.
Jeremiah A.
Problem is solved, the Hardwarekeys didnt work.
I'm glad to hear that the problem was solved. Please reach out if you need more assistance.
Jeremiah A.
