5228 Discussions
S2600BPB(R) Beep Led Problem
PMari9
Hi All,
i'm configuring the S2600BPBR Board and we have some
problem. Below the configuration:
 - S2600BPBR Board
 - N°2 Processor Intel Xeon 4110 Octa core (8 Core) 2,10 GHz
 - N°2 Memory MTA36ASF4G72PZ-2G6J1 - 32GB RDIMM (on CPU 1 Slot A1 and CPU 2 Slot A1)
 - StandBy Power by BackUp Power Control Connector:
  a) GND on Pin 4
  b) 5V_STDBY on Pin 7
 - HDD connected by SAS Interface
We still working for a custom product and we are not using
the Intel Backplane.
When we supply the system, the Amber Led Blink and the LSB
Led stay fixed on the state 1010.
Can someone help?
I attached the video that show the malfunction.
Br, Paolo
SergioS_Intel
Hello PMari9,
We have not tested the Intel® Server Board S2600BPBR with third-party backplanes.
Can you please provide us the model of your back plane? An also the model of the chassis that you are using?
Also, please provide us a copy of the Sysinfo of your server board.
https://www.intel.com/content/www/us/en/support/articles/000023940/server-products/server-boards.html
Sergio S.
A Contingent Worker at Intel
For firmware updates and troubleshooting tips, visit :https://intel.com/support/serverbios
PMari9
SchematichDiagram.JPGDear Sergio,
like explaned, we are not using an Intel Backplane. We are developing a custom design.
We already work on the S2600TP and we supply the standby power by connector Backup Power
and everything work well.
I post to you the schematich diagram of the board connection, so you can understand better
the connection with board S2600BP.
At now, even by powering the card, as requested by the datasheet, the system freezes
during startup and the amber led beeps flash. It appears that the system is not running the
boot.
In the Schematic Diagram, the 12V is not supplye at now, for security
reason. We are using only the 5V on Backup Power Connector.
Can you supply as the minimal connection diagram of the board, so we can understand
if there is something wrong in the minimal connection diagram.
Br PMari.
SergioS_Intel
Hello PMari9,
Can you please let us know the specific part of the board that you the connection diagram?
Sergio S.
SergioS_Intel
Hello PMari9,
I am following your question and would like to know if you need further help.
Sergio S.
SergioS_Intel
Hello PMari9,
I am following your question and we would like to know if need further assistance with your Intel® Server Board S2600BPBR.
Sergio S.
PMari9
Dear SergioS,
sorry if i answer so late. We found the solution at the problem.
Thank you for your help!
SergioS_Intel
Hello PMari9,
We are glad to hear that you were able to solve your problem. We are going to close this thread.
Sergio S.
