5138 Discussions
S2600WFT X722 LOM firmware update
mas90
I have an Intel S2600WFT server with an onboard Intel X722 network chip (LOM).  It currently has firmware version 3.49 and I am trying to update to 4.10 using the package at
https://www.intel.com/content/www/us/en/download/19223/non-volatile-memory-nvm-update-utility-for-intel-ethernet-converged-network-adapter-x722-series-for-intel-server-board-s2600wf-wft-wfq-wf0-family.html
I am attempting to do the update on Ubuntu Linux 18.04.
However, the firmware update utility (nvmupdate64e) claims "Update not available":
Intel(R) Ethernet NVM Update Tool
NVMUpdate version 1.33.15.1
Copyright (C) 2013 - 2019 Intel Corporation.
WARNING: To avoid damage to your device, do not stop the update or reboot or power off the system during this update.
Inventory in progress. Please wait [|.........]
Num Description Ver.(hex) DevId S:B Status
01) Intel(R) Ethernet Connection X722 3.49(3.31) 37D2 00:061 Update not
for 10GBASE-T available
Tool execution completed with the following status: Device not found.
Press any key to exit.
Do you have any suggestions for how to get the firmware update to install?
Many thanks.
Malcolm
mas90
Hi Jose,
I just got around to scheduling downtime for the server to try an EFI update, and it turns out that in the interim a new firmware release had been published ("nvmupdatepackage_wft_wfq_wf0_v5.30.zip") -- and the new version of the Linux updater works perfectly.  So, problem solved!
Malcolm
JoseH_Intel
Hello mas90,
Thank you for joining the community
According to this article How can I Update the NVM on an Intel® Ethernet Network Adapter... if you encounter issues during the update you should contact support which is exactly what you did. Besides the obvious, there is no linux versions for the install package. My recommendation could be to try using the EFI package instead of the OS one. Please give it a try and let us know.
Jose A.
JoseH_Intel
Hello mas90,
I am just following up to double-check if you found the provided information useful. If you have further questions please don't hesitate to ask. If you consider the issue to be completed please let us know so we can proceed to mark this thread as resolved. I will try to reach you back on next Tuesday 9th. After that the ticket will be automatically archived.
Jose A.
JoseH_Intel
Hello mas90,
We will proceed to mark this thread as closed. If you have further issues or questions just go ahead and submit a new topic.
Jose A.
mas90
Hi Jose,
Malcolm
