S5520HC Memory
I have a S5520HC system with dual E5520 Xeons and I want to upgrade the memory to 64GB.
I have 8x 8GB RAM sticks, will they work in that configuration?
I see that your motherboard supports up to 192GB and the CPU supports up to 144GB.
So, 64GB should work fine without any problems.
CPU info: http://ark.intel.com/products/40200/Intel-Xeon-Processor-E5520-8M-Cache-2_26-GHz-5_86-GTs-Intel-QPI Intel® Xeon® Processor E5520 (8M Cache, 2.26 GHz, 5.86 GT/s Intel® QPI) Specifications
Motherboard info: http://ark.intel.com/products/36599/Intel-Server-Board-S5520HC Intel® Server Board S5520HC Specifications
To answer your question, should be no problem at all but we strongly recommend if possible, to avoid compatibility issues; getting validated memory from the following list:
http://www.intel.com/content/www/us/en/support/boards-and-kits/000006908.html Tested Memory and Hardware List for the Intel® Server Board S5520UR Family
