5216 Discussions
Using NTB (Non Transparent Bridge ) to interconnect 2 Xeon based servers
BLaza
Is it possible to use NTB in Xeon servers to connect in a point-to-point manner? Is there any documentation available for the same. I could see NTB support is available in kernel, but not sure how to make use of it for interconnect two servers.
Emeth_O_Intel
Hi Bineesh, The NTB allows hosts on each side of the bridge to exchange indormation about the status through scratchpad registers, doorbell registers, and heartbeat messages. Scratchpad Registers: These r/w from both sides of the NTB. Doorbell Registers: used to send interrupt. These are software controlled interrupt request registers with associated masking registers for each interface on the NTB. These registers can be accessed from both sides. Heartbeat Messages: are sent from primary to the secondary host to indicate it is still alive. The secondary host monitors the state of the primary host and takes appropriate action upon detection of the failure. We like to know if you can provide us with information about the configurations you have set on your systems. >Motherboard model and brand name: >Processor Model and How many processors are you going to use: >Memory: >OS: On the other hand, could you please so kind and provide us the architecture and design that you are trying to implement on your system? I will be waiting your outcome in order to proceed with the next step. Regards, Emeth O. Intel Customer Support Technician Under Contract to Intel Corporation
JoseH_Intel
Hello BLaza, I am just following up to double check if you were able to gather the requested information. Otherwise let us know if you require more time to accomplish this. If you consider the issue to be completed please let us know so we can proceed to mark this thread as resolved. This thread will be marked as resolved automatically in the next 72 hours if no activity is received. Regards Jose A. Intel Customer Support Technician Under Contract to Intel Corporation
BLaza
Hello Jose and Emeth, sorry for leaving it open. The information provided was useful. But we are not pursuing the activity now. Thanks for your support.
JoseH_Intel
Hello BLaza, Thanks for your updates. We will proceed to mark this thread as resolved. If you have further issues or questions just go ahead and create a new topic. Jose A. Intel Customer Support Technician Under Contract to Intel Corporation
