5245 Discussions
customer flagged out received engineering samples
henry828
our customer flagged out they tested SRM7S and got "sample " result.
however, we tested these CPUs by IPDT with no abnormal findings,
so, please help to advise or check if they are ES or not
Intel(R) Xeon(R) Platinum 8468H CPU
batch: J325G451
sn: 72JF616600082
customer test report
 Processor Data:
                                                               Brand Name: Intel(R) Xeon(R) Platinum 8468H CPU
                                                               CPU Type: SapphireRapids
                                                               Revision: 0x09
                                                               S-spec/QDF:   Q1AC
                                                               Sample/Production: 0x00 (Sample)
                                                               Number of Cores: 48
                                                               Hyper Threading: Yes
                                                               System Bus Speed: 100 MHz
                                               Core Data:
                                                               CPU ID: 0x00060F06
        Arch Revision: 0x00
        Core Family: 0x06
        Core Model: 0x0F
        Core Stepping: 0x06
however, we tested these cpus by IPDT with no abnormal findings,
--- IPDT64 - Revision: 4.1.9.41
--- IPDT64 - Start Time: 10/1/2025 11:44:56 PM
CPU1
Genuine Intel CPU Test
Module Version: 1.0.26.64b.W
Start Time: Wed Oct  1 23:44:56 2025
Test Result - PASS
Expected: GenuineIntel
Detected: GenuineIntel
End Time: Wed Oct  1 23:44:57 2025
Total Time: in seconds: 1
CPU1
CPU Brand String Test
Module Version: 1.0.28.64b.W
Start Time: Wed Oct  1 23:44:57 2025
Test Result - PASS
Expected: Intel(R) Xeon(R)
Detected: Intel(R) Xeon(R) Platinum 8468H
Intel(R) Xeon(R) processor detected..!!..
Total Time: in seconds: 0
CPU1
Cache Test
Module Version: 1.0.24.64b.W
Test Result - PASS
 --- Reading Cache Size ---
- Detected L1 Data Cache Size --> 48
- Detected L1 Inst Cache Size --> 32
- Detected L2 Cache Size --> 2048
- Detected L3 Cache Size --> 107520
Cache Size Test Passed!!!
CPU1
MMXSSE Test
Module Version: 1.0.30.64b.W
Test Result - PASS
DetectUtils64 DLL Version - 1.1.9
 --- Determining MMX - SSE capabilities ---
..MMX is supported on this CPU..
..SSE is supported on this CPU..
..SSE2 is supported on this CPU..
..SSE3 is supported on this CPU..
..SSSE3 is supported on this CPU..
..SSE4.1 is supported on this CPU..
..SSE4.2 is supported on this CPU..
MMX Test Result --- PASS
SSE Test Result --- PASS
SSE2 Test Result --- PASS
SSE3 Test Result --- PASS
SSSE3 Test Result --- PASS
SSE4.1 Test Result --- PASS
SSE4.2 Test Result --- PASS
CPU1
IMC Test
Test Result - PASS
--- Reading Memory Size ---
Detected Memory Size is --> 32.00GB
--- Subtest - Memory Size Test Passed!!!  ---
--- Integrated Memory Controller Stress Test ---
Memory to be allocated = 1048576 bytes
Memory Allocated.
Test 1 Ones and Zeros Moving Inversions write operations - Passed
Test 1 Ones and Zeros Moving Inversions verification operations - Passed
Test 2 32Bits Sliding Ones write operations - Passed
Test 2 32Bits Sliding Ones verification operations - Passed
Test 3 32Bits Sliding Zero write operations - Passed
Test 3 32Bits Sliding Zero verification operations - Passed
Memory Deallocated.
--- Subtest - Memory Stress Test Passed!!!  ---
Integrated Memory Controller Test Passed!!!
End Time: Wed Oct  1 23:44:58 2025
CPU1
Parallel_Math_Xeon Test
Module Version: 1.0.0.13
Start Time: 10/1/2025 11:44:58 PM
Test Result - PASS
Module Math_FP.exe Completed - Pass
Module Math_PrimeNum.exe Completed - Pass
Floating Point Test
Start Time: Wed Oct  1 23:44:58 2025
AVX is supported in your OS
Max AVX supported = AVX512
FMA3 supported
Test Result - PASS
Million Floating Points per Second, MFLOPS: 1.69
Error: 0
--- Floating Point Test Passed!!!---
End Time: Wed Oct  1 23:45:43 2025
Total Time: in seconds: 45
Prime Number Generation Test
Module Version: 1.0.29.64b.W
Test Result - PASS
Operation Per Second: 5097809
Error: 0
--- Prime Number Generation Test Passed!!!---
Parallel_Math_Xeon
End Time: 10/1/2025 11:45:43 PM
CPU1
Parallel_FP_Xeon Test
Start Time: 10/1/2025 11:45:43 PM
Test Result - PASS
Module AVX.exe Completed - Pass
Floating Point Test
Start Time: Wed Oct  1 23:45:43 2025
FMA3 supported
Test Result - PASS
Million Floating Points per Second, MFLOPS: 0.13
Error: 0
End Time: Wed Oct  1 23:46:28 2025
AVX Test
Module Version: 2.0.31.64b.W
Test Result - PASS
  --- CPU Features Detection ---
..AVX is supported by this CPU..
..AVX2 is supported by this CPU..
..AVX512BW is supported by this CPU..
..AVX512CD is supported by this CPU..
..AVX512DQ is supported by this CPU..
..AVX512ER is NOT supported by this CPU..
..AVX512F is supported by this CPU..
..AVX512IFMA52 is supported by this CPU..
..AVX512PF is NOT supported by this CPU..
..AVX512VBMI is supported by this CPU..
..AVX512VL is supported by this CPU..
..AES is supported by this CPU..
..PCLMULQDQ is supported by this CPU..
..AVX is supported by this Operating System..
Most Advanced AVX Feature Detected.. AVX512
AVX512 Test Result --- PASS
AES Test Result --- PASS
PCLMULQDQ Test Result --- PASS
Parallel_FP_Xeon
End Time: 10/1/2025 11:46:28 PM
CPU1
Parallel_Xeon_Math Test
Start Time: 10/1/2025 11:46:28 PM
Test Result - PASS
Start Time: Wed Oct  1 23:46:28 2025
Test Result - PASS
Operation Per Second: 4953748
Error: 0
End Time: Wed Oct  1 23:47:13 2025
Floating Point Test
FMA3 supported
Test Result - PASS
Million Floating Points per Second, MFLOPS: 1.56
Error: 0
Parallel_Xeon_Math
End Time: 10/1/2025 11:47:13 PM
CPU1
Parallel_PrimeNum_Xeon Test
Start Time: 10/1/2025 11:47:13 PM
Test Result - PASS
Module FMA3.exe Completed - Pass
Start Time: Wed Oct  1 23:47:13 2025
Test Result - PASS
Operation Per Second: 5887527
Error: 0
End Time: Wed Oct  1 23:47:58 2025
FMA3 Test
Test Result - PASS
..FMA3 is supported by this CPU..
..FMA3 is supported by this Operating System..
FMA3 Test Result --- PASS
End Time: 10/1/2025 11:47:58 PM
CPU1
DGEMM Stress Test
Module Version: 1.0.17.64b.W
Start Time: Wed Oct  1 23:47:58 2025
Test Result - PASS
DGEMM AVX512 Test Result --- PASS
End Time: Wed Oct  1 23:48:58 2025
Total Time: in seconds: 60
CPU1
Frequency Check
Module Version: 1.0.7.64b.W
Start Time: Wed Oct  1 23:48:58 2025
Test Result - NO COMPARE OPTION USED
Processor Name: Intel(R) Xeon(R) Platinum 8468H
Measured Processor Frequency: 2.098463
End Time: Wed Oct  1 23:48:59 2025
System Information
Processor Information: Family 6 Model 8F Stepping 6
Number of Physical Cores: 48
Number of Logical Cores: 96
Operating System: Microsoft Windows Server 2025 Datacenter Evaluation 64-bit
Graphics Information: Microsoft Basic Display Adapter
--- IPDT64 - End Time: 10/1/2025 11:48:59 PM
--- IPDT64 - Result: Pass
Poojitha
Hi henry828,
Thank you for reaching out to the Intel support.  We acknowledge receipt of your concern and want to assure you that assisting you is our top priority. To effectively troubleshoot the issue you're facing, we require some additional information from your end.
kindly provide the following details:
1)Please confirm how you have verified that it is an engineering sample.
2)We request you to review the article below and share the ATPO and FPO details mentioned in it, so that we can validate the part and provide you with an update.
https://www.intel.com/content/www/us/en/support/articles/000021613/processors/intel-core-processors.html
Your prompt response with this information will greatly assist us in diagnosing and resolving the issue as quickly as possible.
We look forward to hearing from you soon.
Poojitha N
henry828
hi Poojitha,
1. used Hwinfo to verify that CPU is ES,
but no idea why the IPDT only show stepping 6 , without any information about if it is ES.
2. FPO: J325G451
  ATPO: 72JF616600082
for all we knew, ES should have their QDF code or Confidential markings,
but the CPU we had got the normal marking "XEON , PLATINUM, SRM7S" ?
Sazirah
Hi henry828,
Greetings.
Thank you for sharing the details.
Based on article 000056190, we can find the brand string on the part, which is Intel Xeon Platinum 8468H and laser markings on it which indicates that this processor is not for engineering sample. Below is the identification methods if the product is engineering sample:
If the part does not have a brand string (for example: “Intel® Core™ i9-9900K”) or the base frequency markings, then it is not a production part.
If you don't find ink or laser markings, the processor may be an unmarked ES processor.
If the part has a label “Intel Confidential”, then it is an ES part.
You may refer link below:
https://www.intel.com/content/www/us/en/support/articles/000056190/processors.html
We recommend your customer to run Intel Processor Diagnostic Tool and share the output with us. Please be inform that tool such as HWinfo might reported wrongly due to CPUID overlap, microcode anomalies or database limitations. Below is the link for the Intel Processor Diagnostic Tool:
https://www.intel.com/content/www/us/en/download/15951/19792/intel-processor-diagnostic-tool.html
Other than that, upon checking the ATPO and FPO details, we identified this CPU as a tray processor, thus we recommend you to reach out to the place of purchased for further support.
Hope this helps.
Sazzy_Intel
henry828
hi Sazirah,
attached is the IPDT test report
Poojitha
Hi henry828,
Thank you for sharing the details. We kindly request you to provide the system information where the processor is installed.
This will help us review the complete details and assist you further.
We appreciate your understanding!
Poojitha N
henry828
hi Poojitha,
one question about IPDT,  if IPDT test will pick up ES and if so, where can we see it on the report.
here is the spec :
System summary:
Windows Server 2022 build 26100 (64-bit),
1 x Intel(R) Xeon(R) Platinum 8468H [2100.2 MHz],
31.7GB RAM,
233GB SSD,
General:
System Name: WIN-N9FNOQSP4SK
System Model: Super Server
Motherboard Manufacturer: Supermicro
Motherboard Name: X13SEI-F
Motherboard Version: 1.01
Motherboard Serial Number: OM255S093029
BIOS Manufacturer: American Megatrends International, LLC.
BIOS Version: 2.6
BIOS Release Date: 04/01/2025
BIOS Serial Number: 0123456789
TPM: Not found
CPU:
CPU manufacturer: GenuineIntel
CPU Type: Intel(R) Xeon(R) Platinum 8468H
CPUID: Family 6, Model 8F
Physical CPU's: 1
Cores per CPU: 48
Threads per CPU: 96
Hyperthreading: Enabled
CPU features: MMX SSE SSE2 SSE3 SSSE3 SSE4.1 SSE4.2 DEP PAE Intel64 VMX SMX Turbo AES AVX AVX2 FMA3
Clock frequencies:
- Measured CPU speed: 2100.2 MHz [Turbo: 2400.2MHz]
- Multiplier: x21.0 [Turbo: x24.0]
- Base Clock: 100.0 MHz
- Multiplier range: Min: x8, Max non turbo: x21 [Ratio: 8C: x30, 7C: x30, 6C: x31, 5C: x31 4C: x32, 3C: x34, 2C: x35, 1C: x38]
Cache per CPU package:
- L1 Instruction Cache: Unknown
- L1 data cache: Not applicable
- L2 cache: Not applicable
- L3 cache: Not applicable
Memory
Total Physical Memory: 32471MB
Available Physical Memory: 29653MB
Virtual memory: C:\pagefile.sys (allocated base size 5120MB)
Memory SPD:
Disk volumes
C: Local Drive, \\?\Volume{e962ff7b-e386-43a5-bdf1-a04c255a5fef}\, NTFS, (232.11GB total, 204.87GB free)
Removable
Disk drives
Disk drive: Model: Samsung SSD 980 250GB Serial: S64CNJ0R807100Z (Disk: 0, SSD, Size: 232.88GB, Interface: NVMe, Volumes: C)
Disk drive: Model: General UDisk USB Device Serial: N/A (Disk: 1, HDD, Size: 7.50GB, Interface: USB, Volumes: D)
Poojitha
Hi henry828,
Thank you for sharing the details. Based on the IPDT test results you provided, we can confirm that the processor is an Intel Xeon Platinum 8468H ( Tray processor) and not an engineering sample.
We would also like to inform you that it is identified as a tray processor. Kindly find the details below for more information:
https://www.intel.com/content/www/us/en/support/articles/000029613/processors.html
Since the processor came along with the Supermicro system but is showing as an engineering sample in the system details, we recommend contacting the place of purchase for further support. They will be able to provide complete information regarding why it is being reported as an engineering sample.
Poojitha N
henry828
hi Poojitha,
 please help to advise if IPDT test will pick up ES and if so, where can we see it on the report.
Poojitha
Hi henry828,
Thank you for your response. As requested, we would like to provide you with additional information regarding the Intel® Processor Diagnostic Tool (IPDT) and its capabilities.
The IPDT performs the following functions:
  1. Verifies the functionality of all processor cores.
  2. Checks the processor’s brand identification.
  3. Confirms the processor’s operating frequency.
  4. Tests specific processor features.
  5. Performs a processor stress test.
Please note that the IPDT does not indicate whether a processor is an Engineering Sample (ES).
For more details on the IPDT, kindly refer to the link below:
Intel® Processor Diagnostic Tool Information:
https://www.intel.com/content/www/us/en/support/articles/000005567/processors.html
To identify whether a processor is an Intel Engineering Sample, please review the following information:
How to Identify an Intel® ES Processor:
We also request you to check the processor details using the utility provided in the link below to confirm the processor status:
Processor Identification Utility:
https://www.intel.com/content/www/us/en/support/articles/000097965/processors.html
As the processor being detected as an engineering sample in system details, we recommend reaching out to the place of purchase for further assistance and clarification.
Poojitha N
henry828
hi Poojitha,
need your help to investigate this case, since according to your and Sazirah's reply,
the part i checked with you can be confirmed as production unit, not engineering sample.
however, we tried to use Intel® Processor Identification Utility, and it shows that it is an engineering sample.
can you explain why a processor with normal brand string marking, which is confirmed as production unit, tested as an engineering sample?
any information can be shared to us for made the things clear ?
henry828
Since we found all the suspected processors tested with showing information as Family 6 Model 8F Stepping 6, any information about the stepping? And what it shoud be if it is a production unit?
