5180 Discussions
memory thrm related warnings/errors on vmware.
RBos
We are experiencing the following warnings/errors and are wondering how we can prevent them.
From Vmware 6.5 directly on Host:
Health of other changed from green to red . Sensor name: Memory Module 2 DIMM Thrm Mrgn 2 --- 0.8.2.177
Health of other changed from red to green. Sensor name: Memory Module 4 DIMM Thrm Mrgn 4 --- 0.8.4.179
Hardware:
Intel 2600TPR within H2224 Chassis
Firmwarelevels:
BIOS ID : SE5C610.86B.01.01.0022.062820171903
BMC FW Rev : 1.50.10802
Boot FW Rev : 1.07
SDR Package Version : SDR Package 1.17
IPMI:
DIMM Thrm Mrgn 1 Normal OK -51 degrees C
DIMM Thrm Mrgn 2 Normal Unknown Not Available
DIMM Thrm Mrgn 3 Normal OK -57 degrees C
DIMM Thrm Mrgn 4 Normal Unknown Not Available
From IPMI we see Sensor 2 and 4 not being available ....is this normal?
Can anyone clarify if this is normal behaviour?
Hello ReneB.
Thanks for contacting us, I'll make some research on this to provide with some recommendations, once I'm done I'll contacting you directly with some recommendations or a plan of action if necessary, should you need anything else please let us know.
Ken
RBos
That would be great,
Thanks in advance.
Hello ReneB.
We have created a support case to keep proper records of this, I sent some instruction to the email you have registered on your account, could you check that up? If so please share your results with us.
Ken
RBos
Hi Ken,
I have not seen an email at my registered emailadres.
Could you send it again?
Rene
Sure, sending it right now,
Please look for case 03061094 related.
Ken
Hello Rene,
Thanks for the reply, I'll keep following up on this at least once a week just to keep track on the case, whenever you're ready please let me know so we can continue.
Kenneth R.
Intel Customer Support
