5105 Discussions
question about connecting SSD to SATA 0-3 in S2600CW server board
akass
Hello
I have sever board S2600cw
I already connected two SSD to the port SATA 4 and SATA 5
now i want to add another two SSD but i was unable to connect them to the sSATA 0-3, SATA 0-3 with the same cable i used for sata 4 , sata 5
what kind of cable i should use in order to connect SSD to the SATA 0-3
Here the picture of the board
Thank you
Here is the part number for the cable you need to achieve the configuration you are looking for:
Mini-SAS Cable Kit AXXCBL450HD7S
akass
