I see the examples in DAAL SVM in C++ and all of them I found that the testing function is working with CSV files.
Is there any function that can work with arrays where the testing function is receiving an array instead of CSV and classifying it?
Thanks for posting in Intel forums. We are checking on this from our side. We will get back to you.
Thanks and Regards
Rahul
Sorry for late reply. We looked into your case. Could you please checkout the below link which has the code to convert your array to a data table (which you can pass it to testing function) and let us know if it works for you.
Hope it helps.
Thanks and Regards
Rahul
We haven't heard back anything from you. Could you please confirm if the issue is resolved.
We haven't heard back from you. So I will close this case for now. If you have any queries you can post a new question.
Thanks and Regards
