I followed the steps to download code samples using Oneapi CLI Samples Browser.
After following the steps I hit Enter:
Create Project Directory mystuff
Project Name vector-add Create Back
Destination: C:\Program Files (x86)\inteloneapi\mystuff\vector-a
I then get the follow error in the command window. I tried it with and without a VPN connection. Any idea what might be wrong?
2020/04/24 09:22:48 mkdir C:\Program Files (x86)\inteloneapi\vector-add: Access is denied.
- Tags:
- General Support
Hi Mark,
As we can see you are trying to create your project vector-add at location C:\Program Files (x86)\inteloneapi\ .So to create a new file in this directory you should have Administrator privileges. In such a case, you have to launch your cmd with run as administrator in order to create your project or you can choose another location to create your project.
This should solve your problem of access denied.
If you still have some issues please report us. We will try to resolve it.
Thank You
Stay Healthy Stay Safe
Abhishek
Hi Mark,
We hope your issue got resolved.
Will you please confirm if your issue is resolved?
Warm Regards,
Abhishek
Hi Mark,
We are closing this thread assuming that your issue got resolved. You can always raise a new thread if you have any issues.
Warm Regards,
Abhishek
