Intel® oneAPI Base Toolkit
Support for the core tools and libraries within the base toolkit that are used to build and deploy high-performance data-centric applications.
419 Discussions
Any plan to support oneAPI on Android?
qxu1
Is there any plan to support oneAPI running on Android? For example, application written by DPC++, or the application based on oneDNN, oneMKL, or the application based on openVINO, can they run on Android?
AishwaryaCV_Intel
Thank you for posting in intel communities.
As of now, there is no android support available. You can refer to the below links to check out the supported platforms and software requirements.
  1. oneAPI DPC++ System requirements
  2. oneAPI Base Toolkit system requirements
Thanks And Regards,
Aishwarya
qxu1
Hi, Aishwarya
Thanks for reply!  Is there any plan to support Android in the near future?
Thanks!
Qing
AishwaryaCV_Intel
Hi Qing,
Currently there is no support of OneAPI for Android, however we've taken the feedback and we'll get back to you if anything changes.
If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks And Regards,
Aishwarya
