Is there a CMake integration for the oneAPI SYCL implementation?
For example for the ComputeCpp SYCL implementation (https://developer.codeplay.com/products/computecpp/ce/guides/integration-guide#UsingCmake
project(my_sycl_program)
cmake_minimum_required(VERSION 3.4.3)
set(CMAKE_MODULE_PATH /path/to/computecpp-sdk/cmake/Modules/)
include(FindComputeCpp)
include_directories(${COMPUTECPP_INCLUDE_DIRECTORY})
add_executable(syclProgram ${CMAKE_CURRENT_SOURCE_DIR}/syclProgram.cpp)
add_sycl_to_target(syclProgram ${CMAKE_CURRENT_SOURCE_DIR}/syclProgram.cpp
${CMAKE_CURRENT_BINARY_DIR})
Or hipSYCL (https://github.com/illuhad/hipSYCL/issues/322#issuecomment-701346003
cmake_minimum_required(VERSION 3.10)
set(CMAKE_CXX_STANDARD 17)
find_package(hipSYCL REQUIRED)
project(LANGUAGES CXX)
# create executable
add_executable(prog main.cpp)
add_sycl_to_target(TARGET prog)
Note the calls to find_package and add_sycl_to_target.
We are forwarding this issue to the concerned team, they will be the right people to answer your question.
Warm Regards,
Abhishek.
We do have a feature request addressing the Cmake integration. I will double check the current state and add you as a one more customer asking for it. I think it should be implemented soon.
