Intel® oneAPI Base Toolkit
Support for the core tools and libraries within the base toolkit that are used to build and deploy high-performance data-centric applications.
Can't log into OneAPI beta
Milstein__Daniel
I got the email approving us for the OneAPI beta:
Congratulations. You’ve been approved for the oneAPI confidential closed beta. Below are the links and information you’ll need to get started.
However, when we go to the page, we get a "permission denied error." This is my login.
Neeraj_K_Intel
Hi Daniel,
We will check with the concerned team regarding the access and let you know.
WILLIAM_H_Intel4
Daniel,
Can you confirm your access now?  It should be enabled now.
William
Shubham_C_Intel
Daniel,
Can you please update us with the status? Are you able to access it now?
Shubham
ArunJ_Intel
We are closing this case assuming the solution provided helped. Please raise a new thread in case of further issues
