I follow below page to try Vector-Add Sample,but I cannot find /opt/Intel folder in my environment.
https://software.intel.com/en-us/articles/using-intel-devcloud-with-oneapi-products
I also reference OneAPI-codesample-beta02-RC2\DLDevKit-code-samples\DNNL_CNN_INFERENCE_FP32\README.md to build this sample,but I cannot find this file "setvars.sh" .
Please help.
- Tags:
- General Support
Hi! In my point of view, when you are using DevCloud, you don't need to worry about setting environment variables - everything was already adjusted for users. As we are building and executing code on a remote node, setvars.sh already exists on it.
You can just follow that Guide step by step. Hope, everything will work!
Wayne,
The issue with the setvars.sh is an issue currently under investigation by the team. I cannot comment on a workaround or fix schedule at this time, but it will be fixed in an upcoming release.
William
Wayne,
Yes, This issue is there on some nodes on devcloud, in the meantime, this issue is being resolved, please try it on some other nodes of devcloud.
Shubham
Wayne, Is this still a problem for you?
If so , is it possible you were on a login node?
oneAPI is not installed on the login node of the DevCloud, only on the compute nodes.
Here is the Getting Started Guide
Also please provide more info:
- what is the hostname of the machine where this issue happened?
- what are the steps to reproduce?
- etc, any relevant info
I have the same problem. I followed https://devcloud.intel.com/oneapi/get_started/baseToolkitSamples/
Step 2 Hello World! Get Started by running a simple sample on DevCloud.
Build and run the sample in batch mode.
source /opt/intel/inteloneapi/setvars.sh
-bash: /opt/intel/oneapi/setvars.sh: No such file or directory.
I also tried
I can't find the opt directory and setvars.sh.
Please see the attached screenshot for more information and let me know how to proceed.
Please confirm that your issue had been resolved. Thanks!
How best can that be with DevCloud, I don't really see how you can use DevCloud without setting environment variables.
