I am trying to install the base toolkit on CentOS 7.6. That version by default comes with GCC 4.8, and the corresponding libstdc++. So to satisfy the GCC toolchain requirements, I have compiled GCC 6.3 from source, along with libstdc++, and put it in my PATH/LD_LIBRARY_PATH.
The OneAPI Base toolkit installation finishes OK. When I run "clinfo" I get the info about the FPGA emaulation platform, as well as my Intel(R) Xeon(R) Gold 6126 CPU. However, when trying to run the simple-sycl-app.cpp from https://github.com/intel/llvm/blob/sycl/sycl/doc/GetStartedWithSYCLCompiler.md I am getting a silent failure (i.e. the results are incorrect - they appear to be memory garbage). If I surround the kernel with try/catch, still no exception is caught.
I assume the problem has to do with my installation, since the same code runs fine on a different Ubuntu system (both CPU and GPU). What could be the cause of this? How could I get more information about where things are going wrong?
- Tags:
- General Support
Thanks for reaching out to us. We are working on this.
Meanwhile, could you try reinstalling oneAPI base toolkit on your machine and check if that works?
Rahul
I reinstalled the latest beta3, but it made no difference unfortunately.
The CentOS 7.6 is not supported. Please check the system requirements for DPC++ compiler here: https://software.intel.com/en-us/articles/intel-oneapi-dpcpp-compiler-system-requirements-beta.
Please make sure your OS, the kernel, gcc are meeting the requirements.
For Ubuntu 18.04.3, the GPU runtime will be installed as part of the oneAPI Base Toolkit installation.
If you'll be using RH, please follow the instruction to install the GPU runtime.
Here is the Installation Guide: https://software.intel.com/en-us/articles/installation-guide-for-intel-oneapi-toolkits
Let me know if you encounter any further issues.
thanks,
Jennifer
Could you please clarify these requirements? For "CPU target", which is how I am trying to use this, it does list CentOS 7.x, and GCC 5+
For using CPU target, i'm assuming you're setting the env like below. the CPU target will use the OpenCL runtime beneath.
EXPORT SYCL_DEVICE_TYPE=CPU|GPU|HOST|ACC
For catching exception, need to add some code like below. try it and see what details you get. But be aware, CentOS is not supported. Also make sure your default gcc points to the newer gcc version. Hope this is helpful.
Code snippets on async exception:
auto ehandler = [](cl::sycl::exception_list exceptionList) {
for (std::exception_ptr const &e : exceptionList) {
try {
std::rethrow_exception(e);
catch (cl::sycl::exception const &e) {
std::cout << "fail" << std::endl;
// std::terminate() will exit the process, return non-zero, and output a
// message to the user about the exception
std::terminate();
queue q(device_selector, ehandler);
q.submit([&](handler &h) {....} );
q.wait_and_throw();
Dmitry Savin wrote:Compiling the gcc manually introduces some ambiguity. Try to install devtoolset-6 (or even devtoolset-8 https://www.softwarecollections.org/en/scls/rhscl/devtoolset-8/) instead.
Is there a way to work with compiled version of gcc and inteloneapi?
