I cam coming from an installed base of MSVC (command line) and Intel FORTRAN on Windows, and Gcc/Clang and Intel FORTRAN on Linux.
I would like to switch to Intel compilers not least of which is compatibility across O/Ss.
I would like to use VS Code as my pseudo IDE... again compatibility. ( I found two VS Code OneAPI plugins ... thumbs up)
The question is can I use "dpcpp" compiler to create MSVC compatible libraries? ( I believe I could do this with the older "icc" compiler)
Would using "dpcpp" instead if "icc" would give us growth potential, that would be lacking in "icc"
Thanks and regards
Carl
Hi Carl,
Thanks for reaching out to us!
Could you please elaborate more on what you meant by MSVC compatible libraries? If possible can you give us an example?
It totally depends on the scenario/task where you wanted to use the compiler(DPCPP or ICC).
ICC (Linux), ICL (Windows) are classic Intel C/C++ Compilers. Whereas, ICX and DPCPP are Intel's new compilers based on LLVM technology plus Intel proprietary optimizations and code generation.
- You may use classic compilers (ICC/ICL) for performance on CPU targets.
- ICX/DPCPP enables Heterogeneous Development across CPUs, GPUs, and FPGAs
Please refer to the below links for more information
Get Started with the Intel® oneAPI DPC++/C++ Compiler:
Goutham
Absolutely I can provide more info, thanks for the reply.
Today we use libraries as provided by bintray, developed by folks like bincrafters. ( Bintray uses Conan for package distribution, https://github.com/oneapi-src/oneMKL uses Conan)
For example: https://bintray.com/search?query=bincrafters
Those prebuild libs are published with the compiler version and options used.
The question is then which Intel compilers produce code that would be compatible with the published libs. Now granted I could rebuild ALL the libs, but lets just say that is a LOT of work.
Does that answer the question?
- Tags:
- Ab
Hi Carl,
Thanks for the info.
We don't officially support the concept of linking a library build with any other compiler using Intel dpc++ compiler. However, if the flags which are used in compiling/creating those libs have equivalent flags in dpcpp as well. So, it totally depends on which libs you intended to use with dpcpp.
In your case, to answer the above question, could you please provide more information about the prebuild libs which you are referring to? And also provide the compiler version and options used in creating those libs. So that we can investigate more on your query.
And meanwhile, If possible could you please try using those prebuild libs with your code using dpcpp compiler and let us know if you face any errors.
Thanks & Regards
Goutham
Hi Carl,
Reminder: Could you please share the above mentioned details.
Goutham
Not sure what to add here. I am going to try the compiler in the next couple of weeks. Until then I wont know for sure.
I will be trying it on a Github open source project so I will share the results here.
Hi Carl,
As you will be trying it in the next couple of weeks, we will be closing this thread here for now. Please feel free to open a new thread once you have the results and we will be happy to help you there.
Have a Good day!
Thanks & Regards
Goutham
